To Go 2.6" Pulley Or Not?
Old Aug 10, 2011 | 08:39 PM
  #51
bboyfreeflow's Avatar
a 2.6 is over spinning/working the supercharger..but give or take it is what it is.. as a member on here posted... he was replacing his blower every 30,000 miles with a 2.5 or 2.6 cuz ur over spinning the blower.
Old Aug 10, 2011 | 08:47 PM
  #52
ecot3c inside's Avatar
your wrong.. obviously you have to taper down the rev limiter, your not over spinning it, but rather getting it to where you want it to be FASTER.
Old Aug 10, 2011 | 09:59 PM
  #53
ebristol's Avatar
The M62 reaches Peak efficiency at 14,000 rpms. Max efficiency is 16,000. Too far past that and it is getting over spun and is producing more heat and causing more parasitic hp loss then extra power.
The size of the sc pulley determine where in the RPM range the blower hits those efficiency points.
Most people say go with a 2.8" because it will hit 16,000 blower RPMs just after 7k. A 2.6" pulley hits 16,000 blower RPMs at 6500 engine rpms. An M62 will still make HP past 16,000 but not very efficiently.
Old Aug 10, 2011 | 10:17 PM
  #54
Erick161's Avatar
Ya I was really surprised it doesn't slip. But from what I read it seemed to be a 50/50 chance of it slipping. You slip with a 2.8"? That doesn't seem right, even with humidity.
Yeah, well i get a screeching belt sound sometimes around 6500-7000rpm...ONLY when its humid/been raining out...At least thats all i noticed. But yeah, its a real GM stage 2 belt from CED.
Old Aug 11, 2011 | 12:42 AM
  #55
G11's Avatar
G11
Originally Posted by Erick161
I see you have a TVS...are we talking about that or the M62?
i had a 2.6 on my m62 too that is what i was refering too lol but good eye!
Old Aug 11, 2011 | 12:47 AM
  #56
Cefaln452's Avatar
you have to make sure your tune is on point, other wise the motor will say **** you and blow #1 and #4 ringlands.... ask me how I know.
Old Aug 11, 2011 | 12:54 AM
  #57
Erick161's Avatar
Yeah, well i def dont have a tuner that i personally can trust...just one that has been recommended to me.
haha thanks. Figured that was the case, but just wanted to check!
Old Aug 11, 2011 | 10:12 AM
  #58
okay... anything below 2.7 ur over spinning the blower dude. jsut be realistic.
Old Aug 11, 2011 | 10:49 AM
  #59
ebristol's Avatar
That plain statement is not necessarily true.
You could run a 2.6" pulley and never "over spin" the blower if you shift at 6500. Just because your rev limiter is set at 7,000rpms does not mean you have to wait that long to ****.
You guys really need to get your sh*t straight. Stop regurgitating what you have heard other people regurgitate and take the time to understand what you are talking about it.
Technically, you can "over spin" the M62 on a 2.9" if you decided to rev out to 7300rpms.
We have already established that the LSJ makes Peak HP around 6500rpms. The only reason to rev past that would be to start at a higher RPM in the next gear. Anything after 6500rpms and the power is falling off.
Do you guys not understand what I am talking about?
Old Aug 11, 2011 | 11:45 AM
  #60
Bluelightning's Avatar
Got Bewst?
So ebristol going to the track would you recommend shifting at 6500 rpm?
Old Aug 11, 2011 | 11:56 AM
  #61
Staged07SS's Avatar
Administrator
Administrator
Listen to this guy.
Old Aug 11, 2011 | 12:09 PM
  #62
Bika's Avatar
Fail Less.
Originally Posted by WickedSS2005
You have to grind the oversize tensioner pulley to fit but if it's not slipping then don't worry. I ran a 2.6 with no other mods than 60's for over a year no problem.
Proof that pulleys dont chunk engines. It's all about the t00n
And heres some advice. When you have a knowledgable veteran posting dyno sheets and trying to drop some knowledge, listen
Old Aug 11, 2011 | 12:20 PM
  #63
Chevycobaltss3's Avatar
I ran a 2.6 and 60s and a h.e for one year as well no issues........ I dont recommend that but it was a testing stage lol
Old Aug 11, 2011 | 01:26 PM
  #64
WickedSS2005's Avatar
For the record, my ZZP 2.6 pulley on the M62 didn't need grinding when I had that pulley
Old Aug 11, 2011 | 01:36 PM
  #65
Erick161's Avatar
I used to be one of those "people". My friend still regurgitates it to me when i tell him im planning on pullying down some more. After doing more research, i have to agree with you (obviously). I think most people were just going under the idea you'd still be shifting at 7000-7400rpm, in which case...yeah...overspinning it.
However, by shifting where the stock limiter is, you're fine. Obviously need the supporting mods (meth seems to be a consistent item, or E85 for you lucky *****!).
Old Aug 11, 2011 | 01:48 PM
  #66
Staged07SS's Avatar
Administrator
Administrator
I hear that the ZZP 2.6" pulley clears the snout.
I'm glad you have confirmed it.
Old Aug 11, 2011 | 01:51 PM
  #67
Over spinning at 7k+. How long are you holding the motor at 7k+ and how often do you go 7k+??? Hmm?? I was about to make a post stating the same thing as Ebristol. He knows this from learning from us veterans that learned from eachother. He is a valuable member and YOU need to listen to what he has posted as I back it up from personal knowledge and experience. Too many of the members that have joined in the last 4 years (since the LNF basically) are just spitting up misinformation. Do some thinking. And while your at it, answer my first question about how long/often you at at 7k+RPM..... It DOESN'T MATTER. The TUNE does....
This is why I don't frequent this forum as much as I used to. No one listens to someone who actually knows wtf they are saying......
No problem man. Honestly, if you have any questions, look me up on FB and get my cell off that
WickedSS2005
Amen to that
Personally, I did my best runs shifting just shy of 7k, drops me back to a better RPM at the next gear
Old Aug 11, 2011 | 01:59 PM
  #68
Staged07SS's Avatar
Administrator
Administrator
WickedSS2005
I appreciate it man. Will do.
Old Aug 11, 2011 | 04:01 PM
  #69
BLue NoTe's Avatar
(Slight jack warning) So the stock crank pulley is 6.3"? I picked up a CA overdrive used a few months ago, would a 2.7 on one of those act as a 2.6?
Old Aug 11, 2011 | 07:13 PM
  #70
Hypothetically, yes
Old Aug 11, 2011 | 07:39 PM
  #71
Nighthawk243's Avatar
Originally Posted by tylerjclance
Germans won't touch my car..
I found one place that will do it but they want 120 euro, which is like... 160 dollars.. to bolt it up
Probably because the number of Cobalts in German are probably easily counted on one hand.
Old Aug 11, 2011 | 07:54 PM
  #72
IonNinja's Avatar
So whats better...running a 2.6 @ 6500 or a 2.8 @ 7000 powerwise? Is it just a difference in low end torque?
Old Aug 11, 2011 | 08:05 PM
  #73
lightningbalt's Avatar
sub. cause i have a 2.6 sitting in my room
Old Aug 11, 2011 | 08:08 PM
  #74
100% METH's Avatar
Oy.....:Facepalm:
There needs to be stickies on some of the information posted here.
I was always under the impression that our crank pulley is 6.5".
Old Aug 11, 2011 | 11:50 PM
  #75
Got Bewst?
Bolt it up. You will love it! If you have meth or running E that is. When I bolted up my long tube and 2.5" catback I noticed a drop in low end torque. Well the 2.6" brought it right back up and more. I love 2nd gear. It pulls hard
