Good or bad ideea?
Old May 22, 2008 | 02:01 PM
sscharged07's Avatar
Good or bad ideea?
I hooked up my water meth injection kit and i cant get it to spray when i want. so what i'm thinking is ditching the boost activation and just hooking it up to a full throttle switch. I'm pretty sure it will work i'm just not sure if it will be safe, what do you guys think?
Old May 22, 2008 | 02:13 PM
LamboW9's Avatar
bad idea...its boost activation or "progressive" controlled for a reason...you spray to much in first gear you culd flood it...i'd ask the company you bought it from....ie devils own, ais, snow, aem whichever
Old May 26, 2008 | 11:32 AM
AIS's Avatar
AIS
Non Authorized / Non-Supporting
Something is not hooked up right. We test every system before it ships to ensure everything is wired and working correctly. I highly doubt the boost switch is not working and something happened from the time it left us to you.
Give me a call directly at 1.801.447.2559 so we can sort this out.
Rodney
Old May 26, 2008 | 11:41 AM
LamboW9's Avatar
an right there is the reason i will be buying from AIS....great customer service
Old May 26, 2008 | 11:42 AM
originaladrian's Avatar
holy crap... thts some of the best service i have ever seen...
Old May 26, 2008 | 11:56 AM
HellbillySS's Avatar
Rodney
This is why they will get my business. Customer service FTW
Old May 26, 2008 | 11:59 AM
LamboW9's Avatar
yea if you read there entire forum as i did you would be even more amazed...i've seen this with AIS... time an time again they always make sure their products work an help out their customer as much as possible through the install an problem-solving...big props to AIS
Old May 29, 2008 | 10:41 AM
AIS's Avatar
AIS
We realize customer service is crucial to this industry and it's customers. Our mission isn't simply to sell you a water methanol injection "kit" leaving you holding all the parts. Our mission is to provide you with the highest quality, most effective, simple, and easy to use water methanol injection systems that are backed by informative technical support and assistance. Most of all, we really enjoy working with customers and getting them set up with a water methanol injection system and hearing the results they gained.
We appreciate everyones support. Thank you.
Rodney
Thank you for your support.
Old May 29, 2008 | 11:30 AM
ralliartist's Avatar
a boost activation switch isn't a "progressive" controller. It reads a certain boost level and then actuates the meth pump at full capacity. So technicall, he could just hook his kit up to a full throttle switch. My boost activation switch messed up as well and I hooked mine up to a full throttle switch. It's perfectly fine.
Just for clarification:
A boost activation switch is a cheap little switch that reads boost and activates pump.
A progressive controller is an expensive controller that lets you start meth at a lower level and progressively get to full injection.
Old Jun 2, 2008 | 01:29 PM
AIS's Avatar
AIS
A full throttle switch works as well. The boost switch's we use are quite reliable. I haven't had many problems with them at all. Was this our boost switch or another competitors?
Oct 13, 2015 09:32 PM
ernnyyes
Oct 2, 2015 05:16 PM
Iceberg
Sep 29, 2015 12:33 PM
jas09ss
Sep 26, 2015 01:06 PM
