Good starting mods?
Old Sep 18, 2013 | 01:37 AM
Gmoney06's Avatar
Good starting mods?
Looking to start getting a few mods. Was thinking first thing would be an airbox mod, just for a little more noise from the blower. Then maybe a good header,downpipe, exhaust combo. What are good header choices?Thinking zzp downpipe, then need some suggestions on exhaust, if even needed?
Pulleys and tuning down the line. Just looking for a good starting point. Read the mod sticky at the top, and was thinking about route 2 with some extras.
Suggestions?
Mike.
Old Sep 18, 2013 | 01:43 AM
beast124's Avatar
good starting point IMO would be stage 2 and an intake..stage 2 alone you will enjoy then go from there with the exhaust mods
Old Sep 18, 2013 | 01:48 AM
southal cobalt's Avatar
get some 60s and a tvs.
if thats too much, do 60s and a 2.8" pulley on m62
if not that, go 42s and a 3.0
if your not feeling any of that, do gms2
if you dont want to go any faster, do exhaust mods and airbox mods first
im just messing around. but zzp is definitely a good place to look. the stock air intake flows great, so airbox mod is a good idea. no reason to spend money where its not needed for an air intake
Old Sep 18, 2013 | 02:27 AM
Gmoney06's Avatar
So I guess I'll start with the mailbox mod and then.save some money and get a gms2 or zzp s2. So injector up, pulley down and then look into exhaust. Got it. What are good exhaust options. Zzp downpipe? Bad mab header? Exhaust system? Worth it? Looking for 250 whp eventually.
Old Sep 18, 2013 | 02:31 AM
buildmeanempire's Avatar
Mailbox mod eh? We're gonna need a how-to for this.
Sent from my Nokia 3100 using CobaltSS
Old Sep 18, 2013 | 07:51 AM
Tjolley's Avatar
The stock exhaust mani is good to 275-300hp or so depending on who u talk to.
The stock down pipe sucks ass. Get a Zzp 3" catted with a 2.5 exit, it will bolt to Ur stock catback. The stock catback will be fine for 250 hp.
Get some gms2 42lb injectors and a 2.8 pulley. Stay away from the 60lb injectors they r ****. If anything get some 50lb from Zzp. I personaly suggest the gms2 42lb injectors.
A intake will have minimal gains but it's good for noise and its easier to Get to the filter i think.
Old Sep 18, 2013 | 07:55 AM
blueLNFftw's Avatar
There is a thread in the fueling section on why they are ****; its is the flow pattern. There is also an in depth reasoning as to why, member research into how to resolve it, and part numbers for ev14 injectors that fit the same and have a proper flow pattern for our head design.
Old Sep 18, 2013 | 07:58 AM
Staged07SS's Avatar
Administrator
Administrator
Gmoney06, please look around the site.
There are tons of threads that will help you out.
Get some gms2 42lb injectors and a 2.8 pulley. Stay away from the 60lb injectors they r ****. If anything get some 50lb from Zzp. I personaly suggest the gms2 42lb injectors.A intake will have minimal gains but it's good for noise and its easier to Get to the filter i think.
I'm with you on this.
I've been running the GM 42's for 6 years now w/o any issues.
Tested many different setups with them as well. Pushed them further than most have on this site.
Old Sep 18, 2013 | 09:42 AM
60s are tried and true. but, if you are looking for a better injector though, injector dynamics have the best injectors available. they are pricey though. the bosch injectors do seem nice, but no one has published the injector data for them yet. thats the great part about ID, is that they send you every bit of fueling information for their injectors. copy and paste into hptuners
people still use 60s, because the data is published for them.
Old Sep 18, 2013 | 10:11 AM
Gmoney06's Avatar
Thanks for all the info guys. So what I'm kinda reading is header and catback are more sound mods unless I'm gonna push past 250 or so. I'll be doing lots more research, just figured some of you that have been into this little longer would have some great suggestions, and it seems I was correct.
Mailbox mod, damn autocorrect. But look for that how to anyways.
Old Sep 18, 2013 | 10:19 AM
Staged07SS's Avatar
Administrator
Administrator
No, they are not just sound mods. You will still gain power.
They just arent req'd until you start making higher levels of power.
For instance, you would be perfectly fine with a legit GMS2 kit and stock exhaust, but will def make more power with a full exhaust.
Old Sep 18, 2013 | 10:55 AM
Tjolley's Avatar
I ran the gm s2 42lb 2.8 pulley and a 50shot for a long time did meny meny pulls with out issues
Old Sep 18, 2013 | 12:24 PM
Staged07SS's Avatar
Administrator
Administrator
Cool beans man
Time attack: 76mm pulley, 42's, 100 shot
Old Sep 18, 2013 | 12:26 PM
mrbelvedere's Avatar
Suggestions?
Mike.
yea I got an idea for you use the search the button there is more info on here then you can imagine so be smarter then the typical parrot on css.net and educate yourself https://www.cobaltss.net/forums/2-0l...-guide-217195/
Old Sep 18, 2013 | 01:23 PM
Gmoney06's Avatar
I did read that guide, hence in my original post I said I'll probably go with route 2. Just looking for suggestions on the correct parts to use, what makes better power, more reliable, etc,etc....
I will do tons of research before actually modding. Just looking for some suggestions from the more experienced ss/sc guys who have been there and done that. Not looking to have info spoon fed as I do love researching on my own. I will search this forum as well as others to get as much info as possible and make sure to post more technical questions in this section from now on. Not an ecotec newbie, just a ss/sc newbie.
Mike.
Old Sep 18, 2013 | 03:32 PM
ill believe it when I see young parrot
Old Sep 18, 2013 | 06:21 PM
always telling everyone to read and search. did you actually read the intro?
The Rookie24
Jan 20, 2016 05:14 PM
chefhhr
Oct 26, 2015 10:36 PM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
QuickSilver_SS
Sep 17, 2015 11:23 AM
ashalle2
Sep 16, 2015 10:36 PM
