got a 2.85 pulley
well if i get a header..my car will be extremly loud right??? and i wanna hear the whine still....can u just get a downpipe on the stock header?
http://www.zzperformance.com/cobalt_...=542&catid=155
you won't hit 19 psi on a 2.85. gut the cat, try again.
95-100 mph is kinda weak man. if you're spinning that means your trap speed is higher then if you hooked. ouchies. somethings goofy. drive mod?
yes you can, trust me though you can still hear the whine with exhuast
not when you spin like crazy like that trust me
Last edited by lsjwannabe; Jan 21, 2008 at 11:58 AM. Reason: Automerged Doublepost
you need to do the boost control for yours. i got first and 2nd to dead hook on the street from a 2k drop
I would deff get your cat checked out. I had a clogged cat on my car and with Stage 2, 2.9 pulley, Cat-back, and airbox mod I was staying dead even with a cobalt that had just a cat-back. I got the downpipe replaced under warrenty and it is a different car now, much better than it was.
I have the ZZP header/catless DP combo going on saturday, I will let you know how loud it is.
yulp. if i have it wide open in 1st and second it would just haze the tires till 60 mph. so i just dropped the boost down.
on 07's the max boost limit only works on 1st and 2nd gears.
patooyee
Oct 1, 2015 01:07 PM
