got a 2.85 pulley
Old Jan 21, 2008 | 11:55 AM
CobaltVenomSS's Avatar
well if i get a header..my car will be extremly loud right??? and i wanna hear the whine still....can u just get a downpipe on the stock header?
http://www.zzperformance.com/cobalt_...=542&catid=155
Old Jan 21, 2008 | 11:58 AM
Area47's Avatar
Rent me! per hour
you won't hit 19 psi on a 2.85. gut the cat, try again.
95-100 mph is kinda weak man. if you're spinning that means your trap speed is higher then if you hooked. ouchies. somethings goofy. drive mod?
lsjwannabe's Avatar
yes you can, trust me though you can still hear the whine with exhuast
not when you spin like crazy like that trust me
Last edited by lsjwannabe; Jan 21, 2008 at 11:58 AM. Reason: Automerged Doublepost
Old Jan 21, 2008 | 12:20 PM
Area47's Avatar
Rent me! per hour
my blower whine with the 2.8 was not there, dropped to a 2.7 and can hear it again
you need to do the boost control for yours. i got first and 2nd to dead hook on the street from a 2k drop
Old Jan 21, 2008 | 12:21 PM
lsjwannabe's Avatar
your a better man than me, i run 50% boost in first and still roast em, i don't know maybe my pcm doesn't listen to me
Old Jan 21, 2008 | 12:22 PM
07 SS/SC's Avatar
I would deff get your cat checked out. I had a clogged cat on my car and with Stage 2, 2.9 pulley, Cat-back, and airbox mod I was staying dead even with a cobalt that had just a cat-back. I got the downpipe replaced under warrenty and it is a different car now, much better than it was.
I have the ZZP header/catless DP combo going on saturday, I will let you know how loud it is.
Old Jan 21, 2008 | 12:23 PM
Area47's Avatar
Rent me! per hour
it does. but you're at 50% of total boost. 45% of mine is 6 psi. 65% is 11 psi. i ramp from 45 up to 70%
Old Jan 21, 2008 | 12:24 PM
lsjwannabe's Avatar
you don't limit second gear do you?
Old Jan 21, 2008 | 12:56 PM
Area47's Avatar
Rent me! per hour
yulp. if i have it wide open in 1st and second it would just haze the tires till 60 mph. so i just dropped the boost down.
on 07's the max boost limit only works on 1st and 2nd gears.
Old Jan 21, 2008 | 12:58 PM
lsjwannabe's Avatar
i was under the impression if i limit boost in second it limits them in all since i have a 06
Old Jan 21, 2008 | 12:59 PM
  #36
Area47's Avatar
Rent me! per hour
yepo. as far as i know. there is another way of limiting it. im just too lazy to go try it
Old Jan 21, 2008 | 01:01 PM
  #37
lsjwannabe's Avatar
yeah lucky you im stuck roasting them, i think im getting new tires maybe that will help
Old Jan 21, 2008 | 01:03 PM
  #38
Area47's Avatar
Rent me! per hour
yepo. i was able to blow them off in second with the 2.8 and bald tires. with new tires, lowered and a 2.7 it just eats the tires alive.
lose lose situation
Old Jan 21, 2008 | 01:05 PM
  #39
lsjwannabe's Avatar
im thinking 225's
Old Jan 21, 2008 | 01:07 PM
  #40
Area47's Avatar
Rent me! per hour
you can squeze 245's under there.
id rather spin. this way i know im not breaking anything
Old Jan 21, 2008 | 01:08 PM
  #41
lsjwannabe's Avatar
yeah i run those at the track, i don't need it for everyday though. maybe a 235 bfg if i can fit it on stock rim
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
