Green gunk for cause of high IAT'2?
Old Jun 13, 2011 | 09:00 AM
CobaltVenomSS's Avatar
ive had high iats for the past 2 weeks or so...so a couple of my buddies routed my opt b a different way to see if it would fix it...and it helped a little but they were still 150+
so we took the bleed line out of the stock heat exchanger and it looked like there wasnt even a hole there so we got a paper clip and cleaned it out and it was just a bunch of green gunk .. so i put more water in and some water wetter also and everything is good now
i just wanna know what that green gunk was and if there is more in the stock heat exchanger
Old Jun 13, 2011 | 09:24 AM
Staged07SS's Avatar
Administrator
Administrator
Hmm that's pretty strange.
Green gunk almost sounds like some sort of copper corrosion residue. What kind of coolant mixture were you using in your heat exchanger?
At least you fixed your problem. I don't know how your opt b. was set up, but always remember to make the expansion tank the highest point in the cooling system.
Old Jun 13, 2011 | 09:28 AM
we put a bunch of washers under the opt B to raise it up im running like 15% coolant 85% water
Old Jun 13, 2011 | 09:34 AM
Staged07SS's Avatar
Administrator
Administrator
Yeah, I used to run an 80/20 mix....
I say just keep an eye on it. Did you flush the system out real good with some fresh water?
Old Jun 13, 2011 | 09:43 AM
Sylver01's Avatar
when dexcool has oxygen trapped in the system it forms a type of gooey gunk. It happened to me in my Grand am. I don't know what color it was but that might be your problem, that is if your using dexcool
Old Jun 13, 2011 | 09:51 AM
Staged07SS's Avatar
Administrator
Administrator
Good point. That could have been the issue.
Old Jun 13, 2011 | 09:55 AM
Sylver01's Avatar
ya. That was the first thing that came to mind when I read "Gunk". I'm kinda leaning toward swapping out the dexcool for the green stuff for that reason alone
Old Jun 13, 2011 | 10:30 AM
i didn flush the system due to im doing dual pass in a couple weeks so it will be flushed then
im just scared that gunk will be in other places too
Last edited by CobaltVenomSS; Jun 13, 2011 at 10:30 AM. Reason: Automerged Doublepost
Old Jun 13, 2011 | 10:32 AM
Sylver01's Avatar
The only way to really be sure would be to do a flush and remove the laminova cores to see if they are plugged. I have a ported intake manifold and will be switching to the green stuff when I change it over
Old Jun 13, 2011 | 10:35 AM
Staged07SS's Avatar
Administrator
Administrator
When you flush it.... Let us know what you find.
Old Jun 13, 2011 | 10:38 AM
will do and ill check all the internals of the intake manifold to make sure they are clean
Old Jun 13, 2011 | 10:49 AM
Staged07SS's Avatar
Administrator
Administrator
Good idea.
Old Jun 13, 2011 | 11:18 AM
Joemaster70's Avatar
whats the easiest way to flush it? run a hose on and wait till it emptys all out? i never flushed my radiator system
turbochargedss2012
Sep 20, 2023 12:17 PM
no_ss
Oct 18, 2015 11:58 PM
Slick_Nick
Sep 28, 2015 09:15 PM
dennis69
Sep 28, 2015 02:16 PM
Dirtybutwhole
Sep 26, 2015 03:29 PM
