Guessing my fuel pump is shot
Old Apr 13, 2011 | 08:35 AM
startingline05's Avatar
On my way to work and my fuel keeps cutting off when I give the car gas and my af gauge reads nothing, it will idle between 13 and 15 on the af gauge. Ia my fuel pump bad? Im also getting a lean code
Old Apr 13, 2011 | 08:38 AM
Kyle4236's Avatar
or clogged?
Old Apr 13, 2011 | 08:43 AM
Well its been doin this for the past month if I went below a quarter of a tank, now its worse and did it with half a tank left
Old Apr 13, 2011 | 09:07 AM
red06SC's Avatar
change filter
Old Apr 13, 2011 | 09:14 AM
alleycat58's Avatar
It's a filter, not the pump. I've never had a pump that would cut in and out, it's either working or it's not. I HAVE had a clogged filter cause the car to cut in and out.
Old Apr 13, 2011 | 11:13 AM
Well damn that sucks cause its a new filter I got with my return fuel setup last month, would the filter cause me to lose pressure? Because after an hour of the car sittin the pressure is back at 0
Old Apr 13, 2011 | 12:06 PM
alleycat58's Avatar
You sure your wiring is kosher? I've had bad fuel pumps before, and they don't "act up" long term. If it's going bad, you've got maybe enough time to get off the freeway so you don't get creamed.
Old Apr 13, 2011 | 12:10 PM
ecot3c inside's Avatar
what fuel are you using? maybe your maf sensor is gone and your code is disabled?
Old Apr 13, 2011 | 12:58 PM
Im running e85, I called ottp and they said my fuel pump is prob bad which is the reason y im losing fuel pressure.
Old Apr 13, 2011 | 12:59 PM
is it possible your e85 mixture at the pump changed to a different blend?
edit: if you lost fuel pressure idk then ^
Old Apr 13, 2011 | 01:00 PM
Red2.4SS's Avatar
Usually a pump failure is a no start issue and it just wont work. Is it loud/noisy?
Old Apr 13, 2011 | 01:32 PM
alleycat58's Avatar
Zactly. First two times I had a fuel pump go it was working fine then not working at all. When it went right after I got the Cobalt, it started, sputtered for 2 seconds, then gone. A bad fuel pump sure as hell won't last a month.
Just out of curiosity, what injectors are you using?
Old Apr 13, 2011 | 02:12 PM
mrbelvedere's Avatar
fuel pumps will start producing less pressure as they go bad then quit working what causes them to star producing less pressure is the brushes are dragging on the com which slows the pump down which produces less and less pressure till they just stop working
Old Apr 13, 2011 | 02:24 PM
This is more like my situation. But im curious because would the pump being bad cause my car to lose fuel pressure with it being turned off?
Old Apr 13, 2011 | 03:03 PM
it will loose pressure over time and it not running thats normal
Old Apr 13, 2011 | 03:32 PM
Ok ottp told me when the car is off its suppose to keep its pressure up on the regulator. Im curious though, the instructions on the return fuel install said to remove the metal mechanism on the stock regulator. Did it just mean the little metal ball or the whole metal piece?
Old Apr 13, 2011 | 08:58 PM
listen its supposed to keep the sysem pressurized when its off for a certain amount of time (usualy 20 min or so) it will bleed off
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
