guys help me
Old Aug 21, 2010 | 12:52 AM
corey_osu10's Avatar
guys help me
ok so today i installed my 2.8 and 60s and an ottp stg2 pcm. after all that it started right up. runs good, idles good. everything is fine. well i went on about by buisness for the today. then when i went out at night i got on it cause i hadnt tested it yet. i was going about45 or 50 in 3rd gear and punched. not totally to the floor but i gave her some juice. it rose about 10 mph and to about 5500 rpms and bam. all the sudden it took a nose dive and the dash said eng pwr reduced. i know that thats limp mode.. well after 3 or 4 turn off and ons, it came out of limp mode and was fine the rest of the way home, but i didnt get on it.. what put it into limp mode? what will fix it? and if it has any effect which i believe it does, after i put the stg kit on it threw code 315 which means i need a crank angle relearn. is this making my car run so rich that its going into protect mode??
Old Aug 21, 2010 | 08:46 AM
joshcsepegi's Avatar
get the crank learn done and if its the ottp stage upgrade for the 60's you will be fine. if you are just adding 60's and not tunned you will continue to have problems.
Old Aug 21, 2010 | 11:13 AM
its the ottp stage kit. i got 60s a 2.8 and a new pcm. is it just that i need a crank angle relearn?
Old Aug 21, 2010 | 11:14 AM
06SuperSportChevy's Avatar
It shouldn't be the case relearn doin that. I raced a mustang gt the first night I installed my ottp stage 2... Past 5500rpm without a single problem. It was also throwing the P0315 code, I think it might be something else puttin it in limp mode. But definatly have it go through a relearn tho for the code.
Old Aug 21, 2010 | 02:02 PM
anybody else?...
Old Aug 21, 2010 | 03:43 PM
startingline05's Avatar
id say get a relearn
Old Aug 21, 2010 | 03:53 PM
raptors_67's Avatar
Is this the thing now? you guys hear this term "case relearn" and think it's a solution for everything?
Old Aug 21, 2010 | 04:01 PM
Dr.Balt407's Avatar
No, i had a pcm shipped from ottp and i went to the dealer and got a case relearn and never had a problem.
its something you should do with a new pcm.
not saying it will solve your problems but if you do it and it still acts up you kno its something else.
well ive heard it from many people, not just on this board, its the only code its throwing, its a logical explenation and thats the only thing thats wrong.
Old Aug 21, 2010 | 04:13 PM
Dr.Balt407's Avatar
i mean your car is tuned, a 2.8, has 60's and a stage 2 belt so what else could be wrong?
Old Aug 21, 2010 | 04:19 PM
sorry that reply was to raptor not you, we posted at the same time. but yes i totally agree, i got the whole kit together and thats the only thing that wrong so i think thats it
Old Aug 21, 2010 | 05:44 PM
no drinking a beer is the solution for everything, in this matter maybe the case relearn will help out alot being that he hasnt done it yet
Old Aug 21, 2010 | 06:00 PM
haha totally agree. i need to get a relearn and that should fix it, then comes the beer!! haha
Old Aug 21, 2010 | 07:10 PM
Dr.Balt407's Avatar
x2
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
roth
Sep 26, 2015 12:16 PM
