Hahn Racecraft LSJ GT35R Turbo Project PICS RELEASED!
Old Dec 22, 2007 | 11:56 PM
  #126
Area47's Avatar
Rent me! per hour
Originally Posted by 06black
SOMETIMES!
i had the car on the raged ****** edge when i was at my 302whp level....
(I<3Bryan)
on a side note, any updates on this???
hehehe
i never said it was easy to do now did i
Old Dec 23, 2007 | 12:25 AM
  #127
Hahn RaceCraft's Avatar
It lives!
Engine sounds good. I have a CEL and a funky idle, but I've yet to peer into the PCM and see what kind of mischief the previous tuner has wrought.
I grabbed some intake manifold detail pics before final mounting it, and I will post them Sunday.
Old Dec 23, 2007 | 12:28 AM
  #128
Raven SS's Avatar
SOMETIMES!
(I<3Bryan)
is this without cracking the engine open?! i am doing a whole rebuild and going to be in the 370-400 whp range on a m62 (until TVS comes out)
Old Dec 23, 2007 | 01:30 AM
  #129
lsjwannabe's Avatar
330~340 is a better estimate trust me
Old Dec 23, 2007 | 01:52 AM
  #130
Coblt ss super's Avatar
how are you going about to doing this? wanna share?
Old Dec 23, 2007 | 01:54 AM
  #131
Smarty Art's Avatar
Has it been said if there is a standalone system being used? If we want to say cam the engine does Hahn lock the tune.
Old Dec 23, 2007 | 02:07 AM
  #132
StinkBOMB's Avatar
X2 Maf resolution is a pain a butt with Gt 35R's, most people go stand alone and use speed density tuning, which leads me to a question for all the Cobalt drivers in emissions testing states, will this kit pass OBD-II emissions tests? Stand alones usually rule out passing an OBD-II emissions test IIRC.
Old Dec 23, 2007 | 02:53 AM
  #133
Onyxd04Redline's Avatar
Wake me up when the dyno numbers are posted please
Old Dec 23, 2007 | 03:10 AM
  #134
06black's Avatar
total stock engine it went 302/298.
it took 6mo of continual work to make it happen, and in the end i wasent happy.
the car had to ride such a razor edge, so thats why i did my sc2061rs swap.
Originally Posted by EcoBoost
It lives!
if you need a hand or anything getting things nailed down in tune, let me know.
theres a few of us who have a nice little sharing circle and we've been able to improve all of our cars thus far.
Old Dec 23, 2007 | 01:01 PM
  #135
Area47's Avatar
Rent me! per hour
braintrust so to speak.
Old Dec 23, 2007 | 01:02 PM
  #136
SSdan's Avatar
06black, are you still total stock engine with the new almost 400whp level?
Old Dec 23, 2007 | 01:11 PM
  #137
06black's Avatar
ThinkTank!!!!
yes sir.
as i've said 100 times....
more then 300hp can be made, yet people call it the limit!!!
when you know the issues the engine has inherently it makes, making power easier
  #138
Herndon_High_SS's Avatar
Sounds like a cobalt-cult to me....
Old Dec 23, 2007 | 01:13 PM
  #139
articzap's Avatar
If you get some good numbers, you guys could blow up like AMS did when they built the 600hp black evo. Take your time and do this right.
Old Dec 23, 2007 | 01:14 PM
  #140
SSdan's Avatar
yes sir.
That's what I call bad ass. I was skeptical about turbo swap because i'm not interested in replacing internals, but you and the rest of the turbo guys are proving GM wrong saying it can't go over 300whp safely.
I'd like to know what happened to Dan's motor though, whether it was installer error or something else....
Old Dec 23, 2007 | 01:19 PM
  #141
06black's Avatar
it was an install issue.....he "forgot" to do a few things.
he makes me tho.....
a better build is in the works.
Old Dec 23, 2007 | 01:20 PM
  #142
I wonder what he forgot??
Old Dec 23, 2007 | 02:14 PM
  #143
Area47's Avatar
Rent me! per hour
think of it as more of a safety number due to other factors than anything else.
Old Dec 23, 2007 | 02:34 PM
  #144
SSdan's Avatar
What are you guys doing about tranny's? LSD/NON-LSD....?
Old Dec 23, 2007 | 07:01 PM
  #145
Back to the thread topic now (y'all may wish to start up some new discussion threads for your corollary topics and post links here, I'd like to keep this thread from wandering off in too many directions for the sake of clarity)....
Got it going well now. We're about to take it out for its maiden voyage in 16 degree weather, lol! As an aside...there's not going to be anything stellar to report on HP levels for at least a week or two, as Joe breaks in the new engine and I move to other projects in the meantime.
The tune will not be locked, so adaptability is there for you. We can also sell the system with no tune or related fuel mods, so you can do as you see fit. We will be offering a variety of fuel system levels:
1. Larger than stock injectors with 20G turbosystem (up to 350 HP)
2. PortFueler with 20G turbosystem (up to 475 HP)
3. PortFueler with GT35R turbosystem (up to 600 HP)
The PortFueler approach is rather unique, in that we will be driving four additional port-mounted injectors in addition to the stock injectors. We've made awesome power with this system on numerous applications previously. It's easy to tune and damned effective!
Originally Posted by StinkBOMB
...a question for all the Cobalt drivers in emissions testing states, will this kit pass OBD-II emissions tests? Stand alones usually rule out passing an OBD-II emissions test IIRC.
This turbosystem will pass an OBD-II test in all its iterations, for it is not a standalone.
You can count on that, my man. I've seen more shattered dreams and disappointments than you can imagine from people who don't understand this fine point.
Here's some detail of the PortFueler-equipped StreetRace Sheemetal Intake:
Above photos show the complete assembly with PortFueler injectors and fuel rail installed. The manifold is also available without PortFueler provisions for those who wish to utilize a single injector per cylinder in the stock location.
These are CNC machined components: the lower is the cylinder head flange, the upper is the plenum back plate.
This view shows the inside of the plenum, with the radiused port inlets.
The oval runners and CNC head flange fit the cylinder head perfectly. The unit completely replaces the stock intake manifold/supercharger/intercooler assembly. It weighs but a fraction of the pieces it replaces, and its compact size improves underhood accessibility of surrounding components. It's a proven design for high power and equal distribution of air to all cylinders.
Last edited by Hahn RaceCraft; Dec 23, 2007 at 10:06 PM. Reason: Automerged Doublepost
Old Dec 23, 2007 | 07:06 PM
  #146
mugencivicsi's Avatar
that is some nice work....
Old Dec 23, 2007 | 07:15 PM
  #147
Very beautiful peice there. Keep up the good work.
Old Dec 23, 2007 | 07:16 PM
  #148
Rodimus_Prime's Avatar
That piece alone makes this kit worth getting but again
prices?
turbo options?
Old Dec 23, 2007 | 07:51 PM
  #149
06blackg85ss's Avatar
that **** is purty.
How much you think that manifold is gonna run minus the injector provisions
Old Dec 23, 2007 | 08:16 PM
  #150
spaz's Avatar
What controls the extra injectors.
