Hahn Racecraft LSJ GT35R Turbo Project PICS RELEASED!
Old Dec 28, 2007 | 02:04 AM
  #201
MVP's Avatar
MVP
man oh man. nice stuff. 06BLK what are we going to do now brother.
mad props to bill hahn and his crew.
Old Dec 28, 2007 | 02:05 AM
  #202
06black's Avatar
Hi mike.
Old Dec 28, 2007 | 02:10 AM
  #203
MVP's Avatar
MVP
Originally Posted by 06black
Hi mike.
sup buddy.
Old Dec 28, 2007 | 04:35 PM
  #204
IonNinja's Avatar
Originally Posted by EcoBoost
One must bear in mind that a MAF sensor reads Mass Air Flow, which is not affected by pressure (density) changes. That's one reason why they are so damned accurate, as they 'see' mass airflow changes that are caused by pressure variations.
There are a couple more advantages to this method:
1. No re-wiring needed, as we have left the MAF in the stock location.
2. As the intake air temp sensor in our MAF location is reading actual intake air temperature delivered to the engine's cylinders (as opposed to ambient temp), it can react accurately to subtle aspects of charge air temperature (which increases with boost pressure) and intercooler performance; changes that would be missed by an ambient sensor. As this reading is used to calculate ignition timing, this is a significant factor. An ambient-only temp sensor is 'blind' to these changes.
this I did not know, thanx for the explinations to the both of you.
I do have another question though, if the MAF is not effected by pressure changes, what causes the MAF to "max out" in some instances?
Old Dec 28, 2007 | 05:38 PM
  #205
BCobaltSS's Avatar
So B do you think this will top your 388whp setup you have on yours
Old Dec 28, 2007 | 06:17 PM
  #206
Hahn RaceCraft's Avatar
You're welcome! What causes the condition you describe is excessive airflow. The MAF outputs a frequency signal that the PCM interprets as airflow in pounds per minute (for instance). The PCM has an upper limit threshold set. Exceed that threshold, and you have 'maxed out' the MAF.
Old Dec 28, 2007 | 06:37 PM
  #207
chevysalesman614's Avatar
looks really good.
Old Dec 28, 2007 | 11:17 PM
  #208
06black's Avatar
G/sec
lol i was blowing by the maf limits at first, once i re-worked the charge pipe i'm good now, toward its limits but still on the chart.
bill do you guys have any worries on this? if this guy has the ported head he clames(not sure if hes a stock cam)then its possibile, highly unlikely with the oem cam but possibile.
we ran outta maf on DJT's car with the 272's and his holset, stock head.
we dont know yet, none the less my plans are still in motion for "phase 3" of this project, once thats accomplished i have no worries beside fullthrottles car.
**** air flow numbers......
Old Dec 28, 2007 | 11:27 PM
  #209
StinkBOMB's Avatar
G/sec
I am curious as well. Even with big MAF setups GT35R's are simply too much for many MAFs. Without taking up too much of your time or prying too much into your bag of tricks are you on stock ECU for this project Mr. Hahn?
Old Dec 28, 2007 | 11:31 PM
  #210
06black's Avatar
not worried man, i'm always one step a head of the curve bro, you know this.
who says a project ever has to end? i think bill will even agree with that!
Old Dec 29, 2007 | 12:32 AM
  #211
spaz's Avatar
Aren't the extra injectors going to compensate for running out of maf headroom.
Old Dec 29, 2007 | 12:37 AM
  #212
06black's Avatar
how you draw that conclusion, i'll never know.
once your off the chart(past maf freq range) it doesn't matter how much fuel you have to play with, the ECM has no way to calculate for it, it'll use its last value and run from that.
Old Dec 29, 2007 | 12:59 AM
  #213
spaz's Avatar
The extra injectors are controled by an external stand alone unit from what I could gather. Is it poss to use a ls2 maf. and rescale it. Or bigger piping and once again rescale it. OR Maybe I am retarded and none of this makes sence.
Old Dec 29, 2007 | 01:04 AM
  #214
Bingo!
Our PortFueler module controls the additional injectors independently of the ECM. We are not limited by this factor.
Last edited by Hahn RaceCraft; Dec 29, 2007 at 01:05 AM. Reason: Automerged Doublepost
Old Dec 29, 2007 | 01:06 AM
  #215
spike's Avatar
^^ i have heard about that ls2 maf thing 2 and i think it will but i would like 2 know if someone has done it........
  #216
With PortFueler, we just don't need to swap MAF's. We can retain the stock MAF and enjoy all the advantages of doing so, but not be limited by it.
Old Dec 29, 2007 | 01:11 AM
  #217
06black's Avatar
Bingo!
the port fueler runs of MAP tho correct?
it doesn't tie into the maf, just a manifold vacuum line or a map signal wire? rite?
Old Dec 29, 2007 | 01:31 AM
  #218
I should explain the system in greater detail.
The PortFueler control module reads RPM and manifold pressure. The module contains its own internal MAP sensor, good to approx. 30 PSI boost. The boost/vacuum signal for this sensor is sourced at the intake manifold.
The internal MAP reading and RPM are used to access values on a two-axis map grid that looks just like a VE table in HPTuners, for instance. Tuning consists of selecting correct values for the different RPM/MAP points on the map grid.
This map grid, in turn, controls the additional injectors. We've shipped hundreds of these systems for other applications, and the feedback is excellent...folks appear to be able to immediately understand and tune the system.
Of course, in our complete turbosystems, the PortFueler maps will be already pre-calibrated. End users can still fine-tune as needed.
Old Dec 29, 2007 | 01:39 AM
  #219
06black's Avatar
i got ya, i think of it like a window switch for a NOS or even more like a meth kit.
vary simple, and extremely effective.
your not bound by factory ECM's or MAF's, ect and it'll still spray no matter what the boost is as long as your turn on point is below 30psi and you have enough fuel pressure.
vary cool dear sir, vary snazzy indeed.
Old Dec 29, 2007 | 09:23 AM
  #220
luciano23456's Avatar
best thread.......EVER! finding out that there was a lsj kit by hahn in r&d is the reason i havent gotten one as of thus far....drive on my good, and kind sir........drive on.
Old Dec 29, 2007 | 10:23 AM
  #221
spaz's Avatar
See I'm not retarded.
I Can't wait for the release of this kit. Do you think before summer?
Old Dec 29, 2007 | 12:44 PM
  #222
06black's Avatar
sure you are.
this has no connection to the MAF what so ever.
my point still stands as valid and correct.
also, i think bill had mentioned that he was planing on having the kit out before summer rolls around.
however i am familiar with the needed R&D behind a project like this and if it doesn't make it out till summer or later i wont be suprised nor disappointed.
its always better to release a kit thats a bit late rather then a kit thats unfinished in any regard.
Old Dec 29, 2007 | 12:46 PM
  #223
SSdan's Avatar
sure you are.
Old Dec 29, 2007 | 01:02 PM
  #224
hizzo3's Avatar
What are the chances of this being modded to fit the 2.4L?
Old Dec 29, 2007 | 01:13 PM
  #225
SilverSS/SC's Avatar
They already have stuff for the 2.4 .
