Harrop TVS 1320 advise please.
Hello all the UK calling
wonder if I could ask for some advice.
I have a Harrop TVS 1320 installed on my 2.2 Z22se running an lSJ TB the internals have all been upgraded Low comp pistons, balance shaft deleted and running comp blower cams. 2.8 pulley.
I am on the oem ecu which has been re-maped for this setup.
I am having trouble every so often, after hard acceleration I am loosing control of the throttle the ecu goes into limp mode, however I do not get any ecu error codes. I was wondering if anyone here has heard of such a thing happening with the Harrops.
has anyone heard of such a thing happening?
Many thanks
Many thanks
Need to look at the predicted airflow and make sure you are not exceeding the limits set. If you exceed those limits the ECM will go in to limp mode as it believes that the throttle body has malfunctioned and is in a run away mode.
Thanks Chaps appreciated
I have had this on and off for some years and never got to the bottom of it I thought it had something to do with my setup, however another chap here bolted on a TVS recently and has exactly the same thing. Unlike yourselves the Z22se ecu has not been fully cracked and so the tuning firm (both used the same 3rd party tuners) have been trying to tune without full access. Excuse my ignorance any idea how I check/correct if I have exceeded these limits? I don't have access to all the technical data from the mapping sessions.
I will do some searching
Josh@ottp
Sep 8, 2015 10:18 AM
