574's TVS mini build
Whats up ladies finally have some parts in my hands so I figured I'd start a build thread. Goal is to be in the 370's and high 11 second quarter.
Stage 2 of 3
Here is what will be going in:
GMPP Clutch
ID1000'S
DW300 fuel pump
2.6 pulley
Stage 2 belt
Stage one tranny mount
Ported head by LSJION (Head gasket and ARP headstuds)
LS4
Catless Downpipe
Catch can set up
And ofcourse the car will be on E85
Anyone have suggestions on other things I should get let me know.
No more wheelhop hopefully!
2.6 big boy boost
Something to get the power down
Oooo
look what just showed up today
Stay tuned for more pictures and I WILL be dynoing this setup in the spring either alone or with Indiana Ecotecs.
Stage 2 of 3
GMPP Clutch
ID1000'S
DW300 fuel pump
2.6 pulley
Stage 2 belt
LS4
Catless Downpipe
Catch can set up
2.6 big boy boost
Oooo
Throw some diamonds on there to be safe? not sure on the install cost of that. but other than that it looks awesome. thanks for responding to my request to make a build thread! Where are you getting the 1000's and how much are they?
well if you dont find them used let me know where you get them. Perhaps if we bought them together it might lower the price lol.... I feel like im not gonna be satisfied and end up getting my head ported and want to drop pullies...
Injectors can be bought from T1racedevelopment.com and probably some other places. Around $450 last I checked plus some other things needed to run them. Look to spend about $500 for it all if buying new.
What tires will you be running at the strip?
I'll be running slicks for sure, I almost picked up a used set on here that were 25" but I heard that's too big
not sure if that gmpp will hold your power man... its good for 300 torque but u might be pushing it. either way that clutch has a lot of slop (at least mine does)
anyway, i love me a 2.6 tvs
consider me subbed in here.
and if you find out the stage1 mount doesn't cut it for wheel hop, i have and extra rear spacer if you want it
Ohh I have the rear spacer too not sure how good it will be but when everything was stock wheelhop was a bitch. As for the clutch zrated was running a lot more power than I will be and as far as I know his held fine so I'm hoping it will be fine haha.
might get a little torque out of the ls4 but idt enough to be worth it... u running a 3" intake? def. run a zzp 3" intake if ur getting the ls4 for best results
