574's TVS mini build
Old Jan 5, 2013 | 09:27 PM
  #76
ThexGovenor's Avatar
Jeez, get ahold of those 1000's? I now have a similar list to you. Im missing a few items but real close... Excited to see what you dyno. I should be around you.
Old Jan 5, 2013 | 09:30 PM
  #77
574's Avatar
574
Didn't order them yet, I could probably get by with my 80's and BRFPS blabla but stage 3/3 of my building process with include cams and the rev limiter will be the moon. therefore I just want to do it once, right.= ID1000'S
Old Jan 6, 2013 | 12:28 PM
  #78
574's Avatar
574
Also can someone tell me what I will have to do to run the 1000's? I think I have to modify my harness but I am not sure and I don't know what to modify
Old Jan 7, 2013 | 09:32 AM
  #79
TStone's Avatar
To use the 1000's? No, I don't believe you have to do anything because they have the same connector as all the other injectors (ev6)..
Old Jan 7, 2013 | 01:31 PM
  #80
jonathan923's Avatar
ask josh(blazin07ss ) on the turbo lsj thread i know hes running them, i think he had to make the hardness or something i could be wrong
Old Jan 7, 2013 | 02:43 PM
  #81
mrbelvedere's Avatar
how do you make a hardness
Old Jan 7, 2013 | 02:53 PM
  #82
lol
Old Jan 7, 2013 | 05:27 PM
  #83
InfraRedline's Avatar
You need to re-pin the harness. Just use the factory one so you can still sell your aftermarket one. You also need the 14mm adapters for each injector to fit, and some extra o-rings.
Old Jan 7, 2013 | 05:32 PM
  #84
574's Avatar
574
where do I get the 14mm adaptor from?
Old Jan 7, 2013 | 05:42 PM
  #85
All from t1 race delopment. Need 4. They are purple!
Old Jan 7, 2013 | 05:52 PM
  #86
574's Avatar
574
Haha alright thanks man
Old Jan 7, 2013 | 07:02 PM
  #87
574's Avatar
574
Uhhh is this a problem?
Not mine:
Mine:
Mine close up of where the plastic pieces should be?
Old Jan 7, 2013 | 07:04 PM
  #88
TStone's Avatar
i don't have those on mine............... i have no idea wtf those are!? lol
https://www.google.com/search?hl=en&...Lazx0wHTlIGABg
Old Jan 7, 2013 | 07:25 PM
  #89
looks like burnt oil just give a good soaking and scrub
Old Jan 7, 2013 | 07:28 PM
  #90
574's Avatar
574
I'm asking why does the other guy have plastic pieces on his valve cover and I don't?
Old Jan 7, 2013 | 07:30 PM
  #91
Your baffle is still in...
Old Jan 8, 2013 | 05:07 PM
  #92
574's Avatar
574
Ill be honest and say I don't know where the baffle is or what it does
Also a minor update: My K&N is pending sale, then I will be buying a used 3" zzp
And this came today so this weekend I should be able to get my tensioner off!!
Old Jan 8, 2013 | 08:56 PM
  #93
Look closely at yours and you see the rivets holding the baffle in. Look at the top pic and see that the rivets have been cut off or drilled out to remove the baffle, most likely to put a larger outlet for the PCV system in.
Also, I live Andes mints!!! (in your pic
Old Jan 9, 2013 | 10:57 AM
  #94
574's Avatar
574
And... K&N is SOLD! Onto 3"
I don't even know if it will make a difference
Old Jan 9, 2013 | 11:24 AM
  #95
zrated89's Avatar
I has 1000s
Old Jan 9, 2013 | 11:26 AM
  #96
doing the tensioner is a MAJOR pain in the ass. heed my advice and check this how to me and my buddy made for loosening the bolt all the way without having to turn your wrench 1/1000th at a time
Old Jan 9, 2013 | 11:27 AM
  #97
p.s. if you happen to need a new valve cover i haz an extra chillin in my basement. it looks kinda crappy like someone tried to paint it or something but eh
Old Jan 9, 2013 | 11:31 AM
  #98
574's Avatar
574
Thats a good idea! And Z you wanna sell me those??
Old Jan 9, 2013 | 11:46 AM
  #99
he aint gonna sell u no 1000's homie wat u cray?
it oughta long as ur running the ls4 tb, otherwise i still can't see the tb making a difference either. all about consistant diameters the whole way through ya know?
Old Jan 9, 2013 | 11:55 AM
  #100
574's Avatar
574
Hey kenny, and taylor: What do you think about having my intake ports cleaned up when I send my head to get ported? Obviously the exhaust ports will be bigger, but I know some people don't even touch the intake side on a supercharged car. Also it will cost extra to have the intake side done, what do you guys think?
