574's TVS mini build
Old Jan 9, 2013 | 11:56 AM
  #101
U dnt want my opinions :X
Old Jan 9, 2013 | 12:22 PM
  #102
574's Avatar
574
U haz no ported head
Old Jan 9, 2013 | 02:26 PM
  #103
zrated89's Avatar
there is alot of uneveness in the casting even on the intake ports. When mine was ported the intake was also smoothed and polished up a little as well
Old Jan 9, 2013 | 08:52 PM
  #104
574's Avatar
574
Alright looks like I'll shell out the extra money for intake porting.
Mini update: war was declared and won against my tensioner, it is off
Old Jan 9, 2013 | 09:00 PM
  #105
TStone's Avatar
Hell yeahh
Old Jan 10, 2013 | 06:06 PM
  #106
574's Avatar
574
Ready to ship out
Yeah I know the motor isn't at TDC lol
I've seen the ports before and have been researching ported heads, now I look back at my stock ones, WOW! And for reference in the one picture, that is a TVS pulley bolt.
Old Jan 10, 2013 | 06:25 PM
  #107
mrbelvedere's Avatar
if you would have pulled the drain plug out of the bottom of the water pump you wouldent have filled the cylinders make sure you clean all the head bolt holes out realy well
the chain wont fall through so no need to hang it u can use a magnet to the chain up to time it
Old Jan 10, 2013 | 06:29 PM
  #108
574's Avatar
574
Okay thanks, this is my first rodeo digging into a car engine
Old Jan 10, 2013 | 07:57 PM
  #109
InfraRedline's Avatar
Just make sure you pull the drain plug in the oil pan to get all the coolant out the bottom before you add oil when its back together! Also what John said, clean all the head bolt holes out before putting the head on or it will push coolant all over your new headgasket and also could fudge the torque reading.
Old Jan 10, 2013 | 08:01 PM
  #110
or break a block
Old Jan 10, 2013 | 08:10 PM
  #111
Its amazing the pressure such a small amount of fluid can create when it has nowhere to go.
Old Jan 11, 2013 | 12:04 PM
  #112
574's Avatar
574
Yeah I will clean the block, my new found friend says he has some special tools for that so I guess I'll find out how good I can get it cleaned out lol. Should I go ahead and drain the oil now?
Old Jan 11, 2013 | 12:09 PM
  #113
yea and clean all the **** out of the bores and wd them down you can take air and blow the head bolt holes out realy good superfly you can get a grey scotch bright pad to clean the deck up and I use starting fluid to make sure the deck of the head and block are oil free before I put the head gasket
Old Jan 11, 2013 | 05:16 PM
  #114
574's Avatar
574
Can a BS delete be done with the motor in the car?
Old Jan 11, 2013 | 06:50 PM
  #115
I wouldent try it
Old Jan 11, 2013 | 06:52 PM
  #116
TStone's Avatar
neutrals would be more practical in this case
Old Jan 11, 2013 | 07:08 PM
  #117
oh yea whats ur redline gonna be at dude?
Old Jan 11, 2013 | 08:15 PM
  #118
574's Avatar
574
It'll be at 7200 for now. But I wanna do a BS delete for the future and so I can do an electric water pump and remove the accessory chain
Old Jan 11, 2013 | 09:01 PM
  #119
you don't need to do a bs delete to run an ele water pump
Old Jan 12, 2013 | 12:32 AM
  #120
Melon's Avatar
I've heard it can b done in car. But dunno how hard it is. I was goin to attempt my delete with motor in car
Old Jan 12, 2013 | 08:48 AM
  #121
go for it
Old Jan 12, 2013 | 11:40 AM
  #122
zrated89's Avatar
the shafts are doable. And honestly i had the motor low enough with the cradle dropped i could have done the delete kit. Just need to have room to press the bushing in. can use a hammer as well
john your saying the timing chain wont come off the crank gear sprocket? I beg to differ when i pulled my stage two cams and sold them i heard the chain come off the sproket and skip a tooth
Old Jan 12, 2013 | 12:20 PM
  #123
Melon's Avatar
Yea in trying to avoid pulling the motor as I don't have a cherry picker or anyplace to put the motor. I've heard of a few members doin it but not sure who. Have to try and dig up the how to, if there is one
Old Jan 12, 2013 | 03:07 PM
  #124
TStone's Avatar
People do neutrals on car.... but "pressing" the deletes in would be quite a headache...
doable? yes... but if I wasn't gonna pull the motor? doesn't seem worth the headache..
Old Jan 12, 2013 | 04:12 PM
  #125
Melon's Avatar
Well hopefully it won't b too bad....
