Has Anyone Swapped Out the Supercharger Coupler
Old Jan 23, 2007 | 08:51 PM
CobaltBlueSS's Avatar
Smile Has Anyone Swapped Out the Supercharger Coupler
I just got my new one from Intense (along with the oil & gasket maker), and was wondering if anyone had done this. If so, are there any special tricks, or things to look out for? Thanks for any and all help,
Matt Gandenberger
Old Jan 23, 2007 | 09:08 PM
plus2ss's Avatar
I had to change the coupler on my 98 gtp. Its the same setup as on our cars. You shouldnt have to remove the s/c to change couplers. All you will need is a 10mm socket, an extension, a ratchet, gasket scrapper, and some brake cleaner to clean gasket surfaces. If the fluid has alot of miles on it, it will smell awful.
Old Jan 23, 2007 | 09:52 PM
06noscobaltss's Avatar
You want to take the blower off. I changed out mine. It takes like 10 secs to pop the other one off. Just pull on it and it slides off if it gives u a lil challenge put a flat head screw driver under it and pry it up. super easy. Get all of the old gasket **** off! other than that let the gasket sealer sit for 10 hours before you drive it! So do it at night!
Old Jan 23, 2007 | 10:27 PM
BlackSS/SC's Avatar
What does the coupler actually do? Help extent life of the SC? Or just needed to be replaced?
Old Jan 24, 2007 | 12:56 AM
The stock coupler can warp under higher heat. So when you throw a smaller pulley on that blower it produces so much heat that the coupler can actually melt causing the snout to spin with the belt but the rotors wont move causing tons of problems. When you put in this coupler it wont melt cause it is made of some special material that can withstand high heat. So that means throw that 2.5" on the SC.
Old Jul 16, 2010 | 03:07 PM
scotch89's Avatar
im about to do this and i was wondering, do u fill the sc with oil until it hits the drain plug threads? or are you suppose to take the sc off and place it on a level serfice and then fill it?????
brandon04
Oct 21, 2015 07:04 AM
ThoR294
Oct 4, 2015 08:44 PM
jimbofug007
Oct 2, 2015 12:06 PM
ThoR294
Sep 28, 2015 05:31 PM
