header and DP
You'll need a different exhaust. The dynomax super turbo muffler sounds pretty good. Whatever you do, make sure you either have a catalytic converter, or resonator, or both. Catless with no resonator sounds way too raspy.
so header catless DP, RES and aftermarket muffler? cause i have an aftermarket muffler now, i was thinking of just leaving the stock resnator on it or will that still make it fart
No dude, the stock resonator doesn't affect the shitty sound of the stock exhaust with no cat. If you have already replaced the factory muffler (which is the culprit of shitty sound when using no cat), you're fine. Although, I'm sure an aftermarket resonator will flow better than the stock one, but I may be completely wrong...I've never looked through a stock resonator.
i ran a cti header and catless downpipe with the stock exhaust for a while, heres a few videos
http://www.youtube.com/watch?v=WxOk-Dhb-jE
http://www.youtube.com/watch?v=Ii3vJ...eature=related
off idle it sounded badass but when it got up about 3k+ to redline it was ok.
z28addiction
09-28-2015 12:03 AM
