headgasket??
sounds like it
check your oil for milky appearance.. also check your oil fill cap... if it's got moisture built up on it then there's probably coolant in your oil and that's a pretty bad thing
Check coolant for oil residue, and check oil for coolant - which will leave oil with a mily appearance, as was mentioned above.
Also, do a compression test. Depending on where it's leaking, it can cause different symptoms.
yeah ill look it doesnt seem real bad yet but i went from running 14's at the track to 14.6's and now when i get toward the end it always says low coolant and my cars running a little hotter then normal and i loose a little bit of coolant ....like i filled up i want to say a day or two ago to the arrow and then it was under the line...and now its at the line but that still means i lost like a 1/4 of an inch to half an inch of coolant ontop of what i topped it off of before that.....
RednBlack
Nov 19, 2009 10:52 PM
2K5SS/SC?
Oct 1, 2007 03:57 PM
