headgasket and ARP studs; Need some guidance
when you say three steps should i torque to say 22 then to like 60 , then 85?
i am doing springs and diamond pistons/NBS/ported head
i also am gonna replace all the hydraulic lash adjusters for piece of mind
LOL if its not one things its another while putting the engine back together I was putting the idler pulley on and I dropped the longer main bolt to it, in the hole of the from located in the wheel well so that sucker is a gonner. Comes to find out its a special bolt that no ace hardware will carry so now its a waiting to game to see when this bolt will arrive.
AHH! WTF! So i finally get the gasket done and start putting the chain on get it set for exh traingle at 10 and the int diamond at 2 and the crank sprocket at 5 and the chains lines up perfectly put the tensioner and everything else related to the time chain and the front cover I got to put on the balancer and torque and noticed it rotated a little. so i rotate the crank to get the 10 and 2 back on the chain and i rotated it 5 or 6 times and the chain did not line up again wtf did i do wrong? I installed it perfectly now the chain is matching up! does this mean i have to take everything again lol and buy the three tty bolts I just bought LOL! ahh this sucks
also when you set up the timing and you had the crank sprocket off did you spin the crank until the accy drive lined up to make sure your balance shafts were in the correct orientation? if you have nbs its not needed?
this could cause unwanted vibration and false knock.
lol yea well I heard it roll down the chassis when it fell into the opening in the fenderwell and I bet its stuck at the bend near the bottom of the frame. so its gone just going to have to order one.
I never removed the the crank sprocket so this maybe a possibility
you can spin it backwards till it lines up for piece of mind, it wont hurt nothing... if you spin it forward it takes a gillion times to line up again trust me i did it, my arm was sore for three ******* days,
otherwise how do you know the lobes on the balance shafts are in the correct orientation as opposed to the counter rotating force?
this timing thing its slightly more complicated then people lead on
very important tool when working on newr cars!!!
http://www.toolking.com/Images/Produ...umWILW9102.jpg
Last edited by hungryhip-ccp; Nov 16, 2009 at 12:02 PM. Reason: Automerged Doublepost
http://toolmonger.com/wp-content/upl...pPliers_TM.jpg
"So here’s how the accessory chain drive should look when
installed correctly. The No. 1 piston should be at TDC, the keyway
on the crank should be in the 12 o’clock position and the
silver link at the bottom of the gear should be in line with the
dot on the crank gear. The intake balance shaft should have the
gold link lined up with the green dot behind the gear, with the
arrow pointed up. The exhaust balance shaft should have the
silver dot lined up with the white dot behind the gear and the
arrow pointed down. Got that? Good."
timing:
"Now is the time to start positioning the cam
drive chain by placing the crank gear with its
arrow pointed in the 5 o’clock position and
this purple-colored link on the arrow.
Position the intake cam gear (it will have an
“I” marked on it) on the cam and hand tighten
the bolts to hold the gear in position. Make
sure the blue colored chain link lines up with
the single line on the adjustable cam gear.
With the chain in the correct position (purple
key on line) on the exhaust cam gear (marked
with an “E”), position it up against the front
of the cam while slightly rotating the cam
clockwise (from the front of the engine) with
a 15/16-inch open end wrench mated to the
slot in the cam to the gear. Hand tighten the
three 13 mm bolts and center 18 mm bolt
until the engine is timed (then torque to
65 ft-lb)."
quoted from the book
Last edited by hungryhip-ccp; Nov 16, 2009 at 12:25 PM. Reason: Automerged Doublepost
its almost my favorite tool next to a remote hose clamp tool.
it works so well i rarly find angles it wont work and usually in that case you can muscle the clamp around a little till you can get the jaws on the two tangs then your golden.
then it always helps you put them back in a orientation to which you can easily access them as well for the future if needed!
pricey i think i paid nearly 100.00 but i usually only buy stuff with lifetime warranty/replacement
