hellp me boost dies 05 ss sc
Old Oct 7, 2010 | 03:00 AM
06cobalt racer's Avatar
Originally Posted by bnm1026
Well it says there is only 5 psi in it but I don't feel any suction but there isnt supposed to be liquid in it correct it seems to just be and overflow also my boost bypass actuator spring is extremely squeaky ? could that be it?
if you look at it there is a fill line on it. you should be able to see coolant
Old Oct 7, 2010 | 03:03 AM
i just came back from running it the boost bypass mod....didnt work i did notice a burning smell while doing it though .... but coolant temp didnt go above 189.... so i have a stage 2 kit from my first cobalt that i never installed.... so i am going to see if i can find the damn thing....i will keep posting my progress in here untill i have a solution thanks guys.... ( it was to plug the hose that came directly from the supercharger to the supercharger bypass actuator correct ( the thing that has a squeaky spring in it )
or is it the second line actually going back to the solonoid... once again thanks
what are you using to monitor the temps? if you are using the dic gauge then that is engine coolant temp not intercooler temp. they are two different systems.
if you can find the stage 2 pulley then put it on and see if that helps.
Old Oct 7, 2010 | 06:48 AM
joshcsepegi's Avatar
i had a similar problem with a 2.7" pulley from zzp. it was belt slippage since i needed the larger idler pulley. i would hit 18 lbs then it would drop to about 8/10 at wot(belt chatter i believe). that could also be your problem. get the stage 2 belt or the larger idler puley
Old Oct 7, 2010 | 09:23 AM
Lifter's Avatar
This.
You need to go back to the basics before trying all of these other things. You're going to cause your self more headache than anything else.
Monitor your IAT2s (Do a Datalog) because the coolant is not your IAT2.
Then swap with the Stage 2 Pulley, and do another datalog. Compare results. You shouldn't have to go through anything else before having tried this first. You've already discovered you're running a sub-3" pulley on a GM Stage 2 tune. That's your problem, as far as we know. SO go back to Complete Stage 2 to see if the problem persists.
Old Oct 9, 2010 | 07:48 AM
bnm1026's Avatar
Originally Posted by Lifter
This.
ok I don't want to sound like a ******* how can I do a data log .... what scanner can I use that has a datalog
Old Oct 9, 2010 | 11:48 AM
Lifter's Avatar
There is an ODBII scanner that lets you datalog, but it's not very good. It does log th IAT2s though.
Other than that, you most likely will need to use HP Tuners or something. I'm sure there's some one in your area that will help you datalog.
Old Oct 26, 2010 | 12:09 AM
bnm1026's Avatar
Thanks to ruler and Chevy ss sc my auxiliary water pump wasn't plugged in when the swap was done that was what they forgot to do I went to take the pulley off and I realized I had to take the charger out I said forget that so I raised the car up to see why I was having a clicking noise and found it then I turn around and find a plug dangling..... so kudos to everyone... oh do they come stock with a front mount heat exchanger.... and is it bad to cut the cat out and can I run race fuel in it
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
