Help with cam grind
Old Aug 4, 2008 | 05:44 PM
Frosty288's Avatar
Help with cam grind
Hey guys...
Blah blah, the guy with the Saab, blah
Anyways, I'm doing a 400whp build and I figured i'd come to you guys when it comes to things like CAMS. I'm not very good with figuring out cams, I know a few things about duration and lift, but not very much. I sent an email over to JBP today asking them about a cam grind.
The car is turbo, it's going to be using a GT3071R, valvetrain, forged rods/pistons, *cams*, and then headgasket/headstuds, 630cc injectors and the walbro 255lph fuel pump with 6-7gph of methanol injection. That's pretty much the meat of the build.
For reference, here is the stock cam profile for the motor:
Will this do it, Frosty?
http://www.saabcentral.com/forums/s...736&postcount=2
Intake 235 deg
Exhaust 240 deg
Ehhh, wait a minute. I got the WIS here. (In case you want to grind your own).
Intake lift 5.75544 mm
Intake open/close 14 BTDC / 41 ABDC
Exhaust lift 5.8703 mm
Exhaust Open/Close 47 BBDC / 13 ATDC
The above data is specific to the 2.0T.
The WIS also lists this spec, which appears to apply to all 4 cylinder motors:
Cam Lift, Inlet Valve 9.70 mm
Cam Lift, Exhaust Valve 9.90 mm
The difference between compressed tappets and expanded tappets is about 2 mm. So, I'm not sure where some of that cam data comes from.
What should I be looking for as far as a new grind?
Old Aug 4, 2008 | 06:02 PM
Area47's Avatar
Rent me! per hour
i take it, your cylinder head is set up like the lsj head with the cam sensor and all that fun stuff?
Old Aug 4, 2008 | 06:07 PM
Frosty288's Avatar
yes it is
Old Aug 4, 2008 | 06:08 PM
Speedytec's Avatar
Sandcast LSJ head = Saab head...
Old Aug 4, 2008 | 06:12 PM
WickedSS2005's Avatar
Click
Old Aug 4, 2008 | 06:20 PM
ItalianJoe1's Avatar
I would guess that something like the 272 grinds some LSJ guys are using would be quite well suited for your turbo app, but I couldn't say for sure.
Old Aug 4, 2008 | 06:29 PM
Area47's Avatar
Rent me! per hour
i take it you have tuning software, ala hpt?
Old Aug 4, 2008 | 06:31 PM
bridfi's Avatar
im gonna throw this one out there...
comp cams turbo grind?
Old Aug 4, 2008 | 06:36 PM
EdCobaltSS's Avatar
272 grinds are perfect for turbo
Old Aug 4, 2008 | 06:37 PM
Frosty288's Avatar
it's going to be custom tuned on the dyno by Nordic in a few months, we don't have HPT software for this ECU
The A/R of the turbo is 0.64, internally wastegated with a T3 turbine housing. I'm guessing the boost will be somewhere near 23psi
can you guys throw links at me?
Old Aug 4, 2008 | 06:39 PM
06blackg85ss's Avatar
stock cams will support a good amount over 400whp.... just look at my car.
on a gt3071 23-24 psi should put you where you want to be
Last edited by 06blackg85ss; Aug 4, 2008 at 06:39 PM. Reason: Automerged Doublepost
Old Aug 4, 2008 | 06:41 PM
Area47's Avatar
Rent me! per hour
ya know. id stick with the stock cams for as long as you can.
i wouldn't upgrade unless it becomes a flow issue across the head itself.
Old Aug 4, 2008 | 06:42 PM
stock cams will support a hair over 475 crank and the stock head is good to abit over 500 so you should be in the clear
LLAMA's Avatar
I don't believe HPT is out for the Saabs
Old Aug 4, 2008 | 06:44 PM
it isn't as far as I've seen from their forums
Old Aug 4, 2008 | 06:48 PM
Area47's Avatar
Rent me! per hour
paul. you're thinking blower stuff. turbo car, different grinds stock
::turns on light bulb::
Old Aug 4, 2008 | 06:49 PM
oh yeah lol. forgot saabs came with the correct setup from the factory
heads are the same, and I don't think the cam grinds could be too different from each other
Last edited by 06blackg85ss; Aug 4, 2008 at 06:49 PM. Reason: Automerged Doublepost
Old Aug 4, 2008 | 06:54 PM
Area47's Avatar
Rent me! per hour
dunno about the grinds. guess if i get bored enough i can dig up the info on them
Old Aug 4, 2008 | 09:57 PM
qwikredline's Avatar
good advice and it is a turbo as you say
Old Aug 5, 2008 | 10:29 AM
Frosty288's Avatar
I posted the stock cam grinds in the OP
I only have one chance really to get it tuned, the guy has to come from Sweden to do it.
Old Aug 5, 2008 | 10:45 AM
Witt's Avatar
The LSJ 272s are reground from LSJ cams with a wider LSA (preserved stock) then he would want. His LSA is a bit too tight for a 272 regrind imo.
I would say something similar to this. Slightly longer duration than stock for higher rpm use, near similar overlap with much better lift.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
