Help!!!!! Fixing this computer codes
Old Aug 31, 2009 | 11:23 PM
"DREAMS"'s Avatar
Lightbulb Help!!!!! Fixing this computer codes
COMPUTER SCAN:---INSTALLED DIAGNOSTIC COMPUTER FOUND CODES poo98 iat sensor2 high voltage,po480 cooling fan 1 control circuit,po315 ckp/cam coorelation not learned,THESE CODES ARE THE SOURCE OF COOLING FAN COMPLAINT AND NO POWER DUE TO ENGINE BEING IN REDUCED POWER MODE.... so anyone of u guy can help me fixing those codes or tell me where to start, im tired of been runing with 3 pound of boost...
Old Sep 1, 2009 | 12:06 AM
bluecobaltss06's Avatar
What year?
Old Sep 1, 2009 | 12:10 AM
"DREAMS"'s Avatar
Originally Posted by bluecobaltss06
What year?
2006 cobalt ss s/c
Old Sep 1, 2009 | 12:16 AM
Nvm. I had this big write up but realised unless you have a lot of experience fixing cars it's not worth the information. If you don't have access to a tech 2 its pretty much worthless anyway. Take it to a local dealer and have them look at it. It could be any number of things, and even unrelated problems. Keep us updated I'm kinda curious
Some quick things I could tell you to try is turn your ac on so the cooling fans are on, and see if they are working. The one should come on and the other should come on when it gets really hot. If they don't come on try swapping the relays for the fan control. But that P0315 you should have looked at. It's a quick learn procedure that you should get done, you need a tech 2. If that code doesn't go away you potentially have a serious problem
Old Sep 1, 2009 | 12:33 AM
"DREAMS"'s Avatar
i do have a tech and im abt to take it to him 2morrow this is the second engine on the car and its got that codes on i had another tech but he charge 85.00 an hr and he want to keep it for 2 days thats lot of cash for some simple like this. i guess, i have stage 3 pulley with a factory stage 2 pc,and the cooling fan stays always on when the car its on and when its on ACC so that means a can not listen to music cuz batt gets down in 5 min. the last engine got messed up cuz i was running water/meth all time but just with water only.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
dieGone
Oct 1, 2015 06:27 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
