HELP ! I need Injectors
Whats up, I had an injector fail on me and I need ONE or a whole set used or new. As long as they are flow tested. So if anyone has a set laying around that went to a different stage or injectors and would like to help out their fellow cobalt brethren. PLEASE shoot me a PM or reply. Im out of a car and its just sitting there and I don't need to drive it for the fact of doing other detrimental damage.
Thank you
C'mon people. I need an injector.
Ill give 75 dollars for one 42# Injector.
Thank you
Just fyi for ya, you need to buy a whole flowmatched set and not just one.
www.lindertech.com
Those are some good guys at Linder if no one else can help you out.
www.lindertech.com
QFT must be. In my experience a GM diagnostic tech 2 can say injector misfire , but taht could be in fact a wire issue connector to wire issue or sparkplug. If you put in new plugs then you have eliminated that....I made the mistake of putting in used plugs once, thought as i did not fix the problem it was injectors, got new injectors, tried it problem remained. Put in new plugs, I fixed it....so big DUH to me....
Sl0wbaltSS
Nov 21, 2018 11:11 PM
