Help me choose proper modifications, pulley size, etc
Old Mar 24, 2012 | 08:45 PM
Mini STSV's Avatar
Hello all, From my introduction thread,
I am in the process of deciding which modifications to make a fun DD out of my cobalt SS / SC.
Currently I have the following items:
A stage 2 OTTP kit, consisting of:
2.8" Smoothflow MPS
60lb Flowmatched Injectors
Injector Harness
Larger Idler Pulley
NGK 1 Step Colder Copper Plugs
OTTP Stage 1 Heat Exchanger
Installed on the car is a cat back exhaust and air intake. I am sending the blower out to Posi Performance to be ported.
Currently, I am considering the following items to purchase from ZZP:
ZZP LSJ Dual Pass Intercooler plate kit w/ Option B & bracket
LSJ Phenolic Intake Spacer
Mid Length Header & Downpipe Combo, 1.75" primary, with spun metal cat
Aeroforce Interceptor Scan Gauge to monitor IAT2s.
ZZPerformance Will tune the car on their own dyno
I think I am going to get a 2.7" Pulley. I have no plans on using meth in my car, and I dont think anything under 2.6" is worth it for a DD.
Here are my questions:
With a 2.7" Pulley, do I need ONLY this oversized tensioner, or should I get the stage 2 belt as well? ZZP Seems to recommend both. I dont mind buying both, but not if they dont work together with a 2.7".
How about a higher flowing IC pump? Did this on my V and it helped out incredibly.
Any other modifications you recommend? Does this seem like a safe setup for a 2.7" DD?
Thanks in advance for everyones input!
Old Mar 24, 2012 | 11:04 PM
MyOtherSS's Avatar
I would order at least the dual pass if your going to be running a 2.8.
Old Mar 24, 2012 | 11:11 PM
Vander Nars's Avatar
I would go with
Badmab Shorty Header
ZZP downpipe catted
ccss3 tuning from chevycobaltss3 on the forums he lives in KY knows his **** with these cars.
Old Mar 25, 2012 | 10:53 AM
Mini STSV's Avatar
Why would you choose the badmab header over the mid length?
Old Mar 25, 2012 | 03:21 PM
Well they was a thread a while back about the Shorty vs long tube headers and pretty much the thread ended up proving that shorty headers was better as no one had dyno proof that long tube made more hp then shorty.
Old Mar 25, 2012 | 04:04 PM
Mini STSV's Avatar
thanks. any other suggestions?
Old Mar 25, 2012 | 05:33 PM
Blowncavy's Avatar
If theres no proof of it, then why is an badmab better witch is what your saying
Not everyone wants cheap ass **** on their car
Old Mar 26, 2012 | 07:33 AM
Mini STSV's Avatar
Old Mar 26, 2012 | 10:35 AM
Jdam8139's Avatar
YESS!!! YOU NEED BOTH. If you don't get the oversized tensioner pulley, look into buying the adjustable tensioner, but idk why you would pay more for the adjustable. Anyway, if you try to run just the S2 belt without the new tensioner pulley, your belt will explode. Ask me how I know
Old Mar 26, 2012 | 12:17 PM
Mini STSV's Avatar
ZZP says theres no point in using a 2.7 over the 2.8 I have already, so I guess that is pointless.
Old Mar 27, 2012 | 07:34 AM
Mini STSV's Avatar
Old Mar 29, 2012 | 07:39 AM
Mini STSV's Avatar
Old Mar 29, 2012 | 07:44 AM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
No real benefit power wise to get the 2.7 over the 2.8
don't waste the time and effort, you're looking at maybe 3whp and a much hotter running car, and a headache.
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
