Help! Taking off S/C...
Old Mar 21, 2008 | 03:48 PM
ptrblkz24's Avatar
Get an allen key and use a pair of pliers and turn it.
Old Mar 21, 2008 | 04:15 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Haha... I tried. The head of the Allen Key ended up rotating a good 25* or so... but not the bolt!
Old Mar 21, 2008 | 04:20 PM
Sunburst_SS's Avatar
get an allen socket with a long enough extension.....take the 2 10mm bolts out that hold the fuel rail in place. Don't remove the rail, but the the bolts out you will be able to push the rail away from the blower a little bit and get the allen socket down on it.
Old Mar 21, 2008 | 04:25 PM
BlilBT's Avatar
Damn it... bumps!
Does anyone know about the Fuel Rail thing? I'm gonna read the LSJ modification book! LoL!
There are a couple bolts that hold the fuel rail on simply remove them & then remove the fuel rail! It is real easy >> It kinda snaps on with orings!
I did the port & polish to mine already>> But the whole inside not just the inlet area!
Just porting it makes it Louder
Old Mar 21, 2008 | 04:40 PM
ptrblkz24's Avatar
Eh,dont worry about it.The allen key wont break till about 45*,lol.Just keep turning it,those bolts arent torqued tightly.
Old Mar 21, 2008 | 04:41 PM
hatrickstu's Avatar
Originally Posted by MP Cobalt
Probably going turbo
lmao way to jump to conclusions
Old Mar 21, 2008 | 04:59 PM
BlackSS/SC's Avatar
All I ever do it loosen the two 10mm bolst on the fuel rail a bit and then the rail will slide back enough to the the allen socket down in there.
Old Mar 21, 2008 | 05:04 PM
AROON02's Avatar
so what is he going to gain out of this project?
Old Mar 21, 2008 | 05:09 PM
rguti153's Avatar
louder supercharger
Old Mar 21, 2008 | 07:17 PM
Yep, that's what I did. I loosened the fuel rail and got to it.
Quite a few things.
1.) A louder S/C
2.) A ******* clean Throttle body and inlet side! Holy hell, that **** was BLACK. I'm plugging my EGR valve ASAP!
3.)A slightly ported Blower!
Originally Posted by rguti153
louder supercharger
That too!
Here is the post I made of what I found, once it was taken off.
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/why-pcv-valves-suck-pics-my-s-c-102549/
Thanks for all the help.
Last edited by USMCFieldMP; Mar 21, 2008 at 07:18 PM. Reason: Automerged Doublepost
Old Mar 21, 2008 | 10:38 PM
  #36
AROON02's Avatar
but if hes sealing the holes up how would it be a "slightly ported" sc?
Old Mar 22, 2008 | 05:24 AM
  #37
Is that a serious question?
I didn't get a slightly ported S/C by filling the holes... I would think that to be obvious. I took a Dremel to it.
Old Mar 22, 2008 | 10:56 AM
  #38
MTchevy1's Avatar
I know you already got it off, but there's a pretty easy way to do it without removing the fuel rail. Just buy a cheapo allen socket and grind down the sides of it on a bench grinder until it fits between the rail and blower. Then you've got yourself a nice specialty LSJ tool lol.
Old Mar 22, 2008 | 03:58 PM
  #39
I'll remember that for next time.
06MetallicBalt
Jul 20, 2025 08:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 20, 2015 09:56 PM
