Help TVS tuning
#52
Can you run a 2.6" pulley on 93 octane? Prob, but with little to no timing.
To make power, you will need timing and the octane to support the timing increase.
Only running 10 degrees timing advance is silly with that blower.
#58
Ok so I just swapped the pulley, changed plugs, and waiting on a new MAF so I can go back and retune it. I'm just wondering if the 25psi is causing a problem too
#68
The table in HP Tuners only goes up to 11,100 Hertz, also as soon as the MAF senses 10,000 Hertz it raises the IDC to 105% causing a huge fuel dump and loss of power.
