help! what does the codes mean?
Old Mar 2, 2008 | 10:05 PM
3fo893013L's Avatar
P0223 and P0123 codes.
what does these two codes mean? friends car is in engine power reduced because of it.
-Mike
Old Mar 2, 2008 | 10:08 PM
BLAZIN07SS's Avatar
I'm too JDM for you
A P0123 code means that the the car's computer has detected that the TPS (throttle position sensor) is reporting too high a voltage.
P0223....Throttle/Pedal Position Sensor/Switch 'B' Circuit High Input
Old Mar 2, 2008 | 10:09 PM
REIGN SS's Avatar
Original Hayden Fanatic
P0123 Throttle Position (TP) Sensor 1 Circuit High Voltage -PCM
P0223 Throttle Position (TP) Sensor 2 Circuit High Voltage -PCM
rockkrawler628's Avatar
-Mike
check this out..
Next time search the premium members aren't paying for wasted server space!
REIGN SS's Avatar
Check for a blown fuse
Old Mar 2, 2008 | 10:11 PM
3fo893013L's Avatar
fuses are fine. car regardless will not remove codes via hpt, removed battery, waited 15 mins won't clear. looks like its going to need to be towed.
with the car right now..
Old Jul 1, 2020 | 08:46 PM
Cam Jones's Avatar
Solution?
Did you ever figure out the problem?
Old Jul 1, 2020 | 09:00 PM
exninja's Avatar
Considering the op's been banned and the thread is 12 years old I don't think he'll respond. Your best bet would be to start a new thread describing your symptoms to see if we can help.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
