HELP!!!! ZZP stage 3
So i installed the stage 3 kit from zzp today, everything went pretty smooth untill i went to start the car. it just clicks like the battery is dead, But its not, and i tried the security realearn with no luck. any help would be great.
Did you try jumping the car? Roll starting it? Did you disconnect the battery before removing the old PCM and installing it? Did you try removing cables and reconnecting on the battery after install?
Joel
Joel
do you still have your old PCM? If so try reinstalling that to see if you have any life.
ya id try jumping the bitch.. if u didnt disconnect the battery while install might have left a light on or something. that killed my battery once ha. jumped it and havent had a problem since. its weird but ya. give it a shot bro.
If it got into your pistons then that would explain why it just clicks, fluid doesn't compress. It would be unable to crank. (unless your starters are strong enough to bend rods, I'm not sure but I'd doubt it).
I'm with Rootbeer though, did you do a dual pass endplate too?
Joel
Joel
