HELP!!!! ZZP stage 3
Old May 22, 2011 | 12:21 AM
wakeoasis's Avatar
So i installed the stage 3 kit from zzp today, everything went pretty smooth untill i went to start the car. it just clicks like the battery is dead, But its not, and i tried the security realearn with no luck. any help would be great.
Old May 22, 2011 | 12:33 AM
CanadianCobalt's Avatar
Sure the PCM is completely plugged in?
Joel
Old May 22, 2011 | 12:43 AM
wakeoasis's Avatar
yea im positive.. im clueless at this point .. my DD too which makes it that much worse
Old May 22, 2011 | 12:45 AM
Did you try jumping the car? Roll starting it? Did you disconnect the battery before removing the old PCM and installing it? Did you try removing cables and reconnecting on the battery after install?
Joel
Old May 22, 2011 | 12:48 AM
denlou's Avatar
And what leads you to conclude it's not a dead battery? If it's the security system, your starter won't even click.
Old May 22, 2011 | 12:49 AM
TiE2000's Avatar
Joel
do you still have your old PCM? If so try reinstalling that to see if you have any life.
Old May 22, 2011 | 12:50 AM
kikal8's Avatar
ya id try jumping the bitch.. if u didnt disconnect the battery while install might have left a light on or something. that killed my battery once ha. jumped it and havent had a problem since. its weird but ya. give it a shot bro.
Old May 22, 2011 | 12:51 AM
Not to worry, my car runs fine .
The OP might want to try this though if jumping it doesn't work.
Joel
Old May 22, 2011 | 12:53 AM
TiE2000's Avatar
Joel
HAHAH sorry posting inbetween games of Halo.
Old May 22, 2011 | 01:06 AM
RooTBeeR's Avatar
curious to see what happens
Old May 22, 2011 | 01:14 AM
wakeoasis's Avatar
yea i tried jumping it off still nothing
Old May 22, 2011 | 01:20 AM
Matt M's Avatar
As already said, I recommend installing the previous ECM to see if it turns over fine. If so, then put the new ECM back in and try the relearn procedure again.
Old May 22, 2011 | 01:22 AM
Bo'Hagon's Avatar
did he order the pcm or just get the file
Old May 22, 2011 | 01:23 AM
RooTBeeR's Avatar
if that doesnt work, someone forgot to do something
Old May 22, 2011 | 01:25 AM
Wait, random question. If he puts in the stock PCM with the stock tune won't it be er.. not good when it starts?
Joel
Old May 22, 2011 | 01:26 AM
Bo'Hagon's Avatar
Originally Posted by Bo'Hagon
did he order the ecm or just get the file
did you buy the ecm from them or the file
Old May 22, 2011 | 01:37 AM
RooTBeeR's Avatar
Joel
well as long as it does more(turn over/try to start & run)
but even with bigger injectors on a stock tune should fire/run...just not right
Old May 22, 2011 | 01:48 AM
TiE2000's Avatar
Yea he will be fine as long as he stays out of boost. Idling in his garage wont hurt a thing
Old May 22, 2011 | 02:06 AM
wakeoasis's Avatar
pretty sure my car is F***** just pulled the supercharger and intake .. all full of coolent
Old May 22, 2011 | 02:13 AM
kikal8's Avatar
WTF?! how did that happen if the car didnt even start?!
Old May 22, 2011 | 02:15 AM
RooTBeeR's Avatar
because something wasnt sealed up/put back properly and it seeped in would be my guess
from the intercooler system...dual pass(core swap) would make sense
Old May 22, 2011 | 02:16 AM
DiabeticKripple's Avatar
Well there's Your problem
Old May 22, 2011 | 02:19 AM
RooTBeeR's Avatar
did you do a dual pass also?
Old May 22, 2011 | 02:24 AM
If it got into your pistons then that would explain why it just clicks, fluid doesn't compress. It would be unable to crank. (unless your starters are strong enough to bend rods, I'm not sure but I'd doubt it).
I'm with Rootbeer though, did you do a dual pass endplate too?
Joel
Old May 22, 2011 | 02:25 AM
RooTBeeR's Avatar
pull spark plugs see if theres coolant on top of the pistons
