hesitation?
Old Aug 11, 2010 | 08:15 AM
kyle1853's Avatar
hesitation?
ok so every now and then in second gear under wot i get this hesitation....no knock showing....no miss that i can tell .....and no cel ......any thoughts....changed the plugs to just to make sure...i was thinking maybe maf needs cleaned and a new air filter...
Old Aug 11, 2010 | 08:20 AM
iboost's Avatar
happens with me in early mornings after I let my car sit over night...happens for about the first 15-20 seconds of driving my car...Still haven't figured it out.
Old Aug 11, 2010 | 08:23 AM
Staged07SS's Avatar
Administrator
Administrator
Hmm .... I would check those things.
My car has been experiencing spark blow out ever since I installed my H62 blower. It only happens once in awhile, but def causes a noticable hesitation under WOT. I'll be switching the stock plugs (gapped at 0.035") out this week with one step colder plugs (gapped at 0.032"). Hopefully, that solves my issue.
Old Aug 11, 2010 | 08:39 AM
kyle1853's Avatar
yeah it doesnt matter...i would say its when my cars warmed up...cause i never really beat the **** out of it while cold so i dont know about it then......but yeah mainly it does it when im getting ready for a highway pull...race from 40 to 60....second gear only...like a second to 3 seconds after i wot it
and one time it did it twice in a row..not like pull then pull ...like in the same pull....thats when it started to worry me....
Old Aug 19, 2010 | 09:51 AM
Staged07SS's Avatar
Administrator
Administrator
Hey man I just experienced this last night in 2nd gear. I tired to see if I could get it to happen again, but I made two more clean pulls w/o issue. I had zero knock & zero missfires. I'm going to look into this some more. I'll let you know what I find out.
Old Aug 19, 2010 | 09:57 AM
kyle1853's Avatar
Originally Posted by staged07ss
hey man i just experienced this last night in 2nd gear. I tired to see if i could get it to happen again, but i made two more clean pulls w/o issue. I had zero knock & zero missfires. I'm going to look into this some more. I'll let you know what i find out.
yeah thats exactly what i was doing....now im getting my supercharger gasket changed...i dont know if that was an issue...i was showing no knock or misfire or codes...so i was trying to get it to do it and watch the igntion timing...maybe something is happening and it is pulling timing so much that it feels like a hesitation////?!?!
Old Aug 19, 2010 | 11:30 AM
Staged07SS's Avatar
Administrator
Administrator
Well, my supercharger gasket is brand new, so I know thats not my issue. It never did this until i installed my new plugs. I installed the new plugs, because I was experiencing spark blow out with my stock plugs (plus it was time for 1-step colder plugs). I'm going to check my plugs this afternoon. I may need to open the gap up slightly. I'll let you know how it goes.
Old Aug 19, 2010 | 11:50 AM
kyle1853's Avatar
well, my supercharger gasket is brand new, so i know thats not my issue. It never did this until i installed my new plugs. I installed the new plugs, because i was experiencing spark blow out with my stock plugs (plus it was time for 1-step colder plugs). I'm going to check my plugs this afternoon. I may need to open the gap up slightly. I'll let you know how it goes.
yeah i changed mine to to the breke7 or whatever the copper one step and gapped it .035
Old Aug 19, 2010 | 11:54 AM
Staged07SS's Avatar
Administrator
Administrator
My factory plugs were gapped at 0.035, but ever since I installed the H62 blower I started experiencing spark blow out every once in a while. So i closed up my gap to 0.032 on my new plugs, but I think that is to small for my application (or my car doesnt like it, haha), and may be the reason my car hestitated. I'm going to check them today to see if they are burning correctly.
Old Aug 19, 2010 | 01:34 PM
kyle1853's Avatar
K let me know what you find!!! )
Old Aug 19, 2010 | 02:05 PM
Staged07SS's Avatar
Administrator
Administrator
Will do !
Old Aug 19, 2010 | 02:10 PM
kyle1853's Avatar
So how did you get that supercharger anyways...and does it sound different...or what is the difference?
Old Aug 19, 2010 | 02:14 PM
Staged07SS's Avatar
Administrator
Administrator
I have my connections, haha.
It sounds different, and performs a good deal better. I felt a nice bump in power from it when I installed it over 2 months ago. The main difference are the high helix rotors. They have a higher degree of twist (120*) vs. the m62's (60*) twist rotors. The outlet triangle of the housing is also slightly ported.
You can see what it looks like in my images.
Old Aug 19, 2010 | 02:20 PM
joshcsepegi's Avatar
i always thought it was my power enrichment kicking in. it happens to me almost every time.
I just assumed that zzp's tune the pe was to high so i saw it till 2500rpm's
Old Aug 19, 2010 | 05:42 PM
kyle1853's Avatar
Originally Posted by joshcsepegi
i always thought it was my power enrichment kicking in. It happens to me almost every time.
huh lol
Old Aug 19, 2010 | 05:54 PM
light'bolt's Avatar
I know this is a long shot but have y'all changed your VE tables yet??
Old Aug 19, 2010 | 06:58 PM
Dainslaif's Avatar
It's because your engine is not at operating temp so it's not getting full combustion, derp.
For the others in this thread, if your engine is at operating temp, it's because you are tuned rich, most likely in the VE table as stated above.
Old Aug 19, 2010 | 07:52 PM
Staged07SS's Avatar
Administrator
Administrator
My car is not tuned rich.
Its running much better now that I adjusted my spark plug gap. My car didnt like the common 0.032" plug gap that everyone thinks is best for these cars. She used to run like a champ with the stock plugs gapped at 0.035" (only experienced blow out issues randomly), so I re-gapped my new plugs to 0.034". Worked wonders. The car feels smoother and much more responsive now.
I figured that was my issue considering I never had any hesitation problems before I installed the new plugs. I had spark blow out issues, but never any hesitation.
Old Aug 23, 2010 | 11:23 AM
kyle1853's Avatar
Since i had my super charger gaskets replaced it doesn't hesitate now...i dont know if that fixed my issue of running good tho...but anyways last night i was doing a pull and it felt so weird....i floored it in 2nd and it felt like the tires broke loose but they didnt...and i thought the clutch was slipping but it wasn't.....hasn't done this since.....but i did have a very bad hub bearing....?!?! Any thought..???
Old Aug 23, 2010 | 11:29 AM
kyle1853's Avatar
Hey so does that blower make more boost or anything??? And how much of a power gain would you say.....
Old Aug 23, 2010 | 12:57 PM
Staged07SS's Avatar
Administrator
Administrator
Yes it does ....
It was dyno tested at 20 whp over an M62 at any given pulley size. That was from simply bolting it on like I did. If i fine tuned for it I'm sure I could see another 10 whp or so.
Old Aug 23, 2010 | 02:36 PM
kyle1853's Avatar
yes it does ....
It was dyno tested at 20 whp over an m62 at any given pulley size. That was from simply bolting it on like i did. If i fine tuned for it i'm sure i could see another 10 whp or so.
so you did no tuning at all ...just bolted it on? Thats awsome...and ran great....sound different or louder...got any clips.....is it possible you could hook me up lol
Old Aug 23, 2010 | 02:40 PM
1 SLOW SS's Avatar
kyle problem is your front plate slowed you down thats why dustin was catching up and it was installed by blackhawk thats another reason probably if you would of had your hideaway plate down you would of won lol by the way did u see that 300c racing with us haha
sorry for the thread jack continue
Old Aug 23, 2010 | 03:05 PM
Staged07SS's Avatar
Administrator
Administrator
Just bolted it on.
The H62 runs fantastic with my GM Stage 3 tune. It produces a good deal more low - mid range power than the M62 along with great top end. The whine is deeper and more pronounced sounding than the M62. I dont have any clips of it yet, but as soon as I do they will be posted.
I cant hook you up, because only 3 were ever documented to exist.
1. Time Attack SS/SC
2. Time Attack SS/SC back up engine
3. Spare (aka. mine)
There has been rumor that 7 were made total, but I go by my total, because it from a reliable source.
Old Aug 23, 2010 | 03:28 PM
kyle1853's Avatar
Not gonna lie....very jelous.....you should sell to me... Lol
IS IT STILL A ONE LITER
