higher iat2 numbers after h/e install
I installed my zzp h/e and after my iat2 numbers are noticeably higher than before, im aware my pump is probably gone but my iat numbers were around 135 avg and dipped to 120 some, before it was around 100-110 sometimes lower. It had hit higher numbers before i remember hitting 140 a time or two but now its at 140 alot....is it just the pump? Just confused why its higher after...
U need to bleed the air, its easy to fill it on the tap but u gotta do it a few times as air makes it way to the top of the heat exchanger that was the mistake i made at first but im getting it fixed now
I "assume" my pump is gone because i have 52k on the car and its an 07 so i inagine its gone i havent ever found out for sure yet, but if thats the case i imagine i cant bleed it until thats right...
Hockey:i saw your post i was just asking a specific question about option b, i think i will figure out if the pump is bad, not very inclined on these things but gonna try and if its bad get a new one
Ive been told a few ways to tell then someone tells me the other way isnt fool proof so idk i have a way my tuner gave me to use the fuse and see but he needs me to make something to trigger it and hell if i know how to do it...
Make sure there is plenty of coolant in the intercooler system, then open the cap on the fill neck while the car is running. If you don't see a spinning vortex of coolant in the fill neck after running for a minute or two, it is more than likely not working
^the reason u see no coolant in the neck is because its not full, air gets trap in the system and takes a while to work its selfout, if u have the stock H/E and no opt b then ur stuck filler the neck up everyday till the coolant is full and all the air is out and this can take weeks lol, this is why the opt b was made, i however have zzp stealth H/E and I made the mistake of not topping it off after air had made its way yo the top of the system so when I checked mine 2 days ago I was able to add a fair amount of coolant, im drive it around for more days let anymore air bleed to the top and fill it again then get new results to post for my h/e since the last ones i posted was not on a fully bleed system. My advice to u is get an opt b and follow the instructions, i messed up first time i installed one and it didnt work correctly but when i installed it for my friend i did it right that time and it works great for his setup.
