How does this happen?!
Old Jun 2, 2013 | 11:35 PM
Mendomar06's Avatar
Idk what happened, I was at wot car dies n find this laying 50 back lol
Old Jun 2, 2013 | 11:42 PM
DiabeticKripple's Avatar
hey Marco!
a local here had the same thing i think.
Old Jun 2, 2013 | 11:46 PM
SylverSS/SC's Avatar
Not really Jordan. His bolts broke, not the pulley itself.
Looks like your supercharger got stuck or seized. Pulley might have already had a crack in it?
Old Jun 2, 2013 | 11:50 PM
EXsoccer1921's Avatar
well i can tell you one thing, that snout was not machined properly. and the bolts look like they're flush with the hub, which there should be a gap the thickness of the pulley.. obviously lol. which is reflected in the pulley on the top bore where it looks like the bolt was tightened so much it compressed. and the other three bores look like they're flared out almost as if someone tried to increase the diameter for some reason and didn't clean off the burs. it's just aluminum..it has a tolerance..
also looks like the hub was grinded on? around where the bolts go through?
Old Jun 3, 2013 | 12:19 AM
Mendomar06's Avatar
Nope pulley was brand new bro, n I don't think my dad overtightened them. What do you mean the snout is machined wrong?
Originally Posted by DiabeticKripple
hey Marco!
Hey Jordan, how you been
hey Marco!
Old Jun 3, 2013 | 12:20 AM
Mendomar06's Avatar
It looks almost as if the pulley was pulled right off the hub
Old Jun 3, 2013 | 12:23 AM
Mendomar06's Avatar
Charger spins freely so go figure
Old Jun 3, 2013 | 01:13 AM
im good. hows life?
Old Jun 3, 2013 | 01:32 AM
Mendomar06's Avatar
Good just working, Aldo just bought my first home
Old Jun 3, 2013 | 09:34 AM
mrbelvedere's Avatar
bolts over tightened maybe
Old Jun 3, 2013 | 09:41 AM
Mendomar06's Avatar
Maybe but I'm thinking I was using the wrong belt, I'm running a stage 2 belt on a 3" pulley. Idk if that matters or not
Old Jun 4, 2013 | 08:22 PM
MyOtherSS's Avatar
Stage 2 belt is fine with a 3" pulley.
Old Jun 4, 2013 | 08:50 PM
redcobalt07's Avatar
Cheap pulley?
Old Jun 5, 2013 | 07:16 AM
sLAsh's Avatar
Bolts loosened up and moved in hub every time you hit boost?
The bolts are tougher than the pulley so they would abrade the pulley until it got weak enough to break.
Like when wheel nuts are loose and oval out the holes on a rim.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
agentirons
Oct 16, 2015 02:11 AM
jmelton327
Sep 26, 2015 10:04 PM
jcarroll53
Sep 24, 2015 07:43 PM
