how does zzp longutbe catted sound with stock exhaust?
Old 04-20-2012, 02:04 PM
HMM thats wierd everyone else is saying its like stock pretty much maybe you had a leak? i guess thats the reason my old zzp dp rasped bad
Old 04-20-2012, 02:13 PM
RooTBeeR's Avatar
No I didn't, had new gaskets and used sealant on the v-band. i think its partially from it being catless and partially from the header having thiner primary walls compared to the stock mani
i wish i could have gotten some fly bys before i changed it back to stock
Old 04-20-2012, 02:24 PM
ebristol's Avatar
I will do my best to get all the vids I can.
Old 04-20-2012, 02:36 PM
insylem's Avatar
good to hear, so noone has any vids? XD
If I remember this weekend sometime Maybe I'll make one.
Old 04-23-2012, 03:35 PM
^^ did u remember??
ohhh it was catless. yea thats ur problem i thought it was catted.
Old 04-23-2012, 03:36 PM
only vid i can find. said mods form description: 241 wheel HP, 220 wheel torque, through an LSD trans. Mods are ZZP 3" Catted down pipe, modded air box, 2.8 pulley, 60lb injectors, ZZP Stage 1 heat exchanger. Stock cat-back, stock intake tube. It was dynoed in 96 degree heat in 90% humidity by Jeff Creech at Carolina Auto Masters in Durham, NC. Had it been a cooler day, the numbers would be a good bit higher, but overall I am very pleased
i guess it does sound kinda like stock
Cobalt SS Supercharged Dyno - YouTube
Old 04-23-2012, 03:37 PM
i did maybe hear a little rasp during the pull
Old 04-23-2012, 05:06 PM
ebristol's Avatar
I should have my video up tonight.
Old 04-23-2012, 05:22 PM
kdub1492's Avatar
You are going to hear rasp no matter what you put on your car, unless you go back to complete stock. Its the price that is paid for modding your car. Even if you get a catted DP from ZZP, that cat is less restrictive then the stock cat. It's going to be a little louder and will probably create rasp. You were talking about going TVS, so I would probably just get used to your exhaust being a little louder, especially if you want to get the max potential out of your motor.
Old 04-23-2012, 10:33 PM
ebristol's Avatar
Here is a link to my video.
Guess who's back, back again... - Page 4 - Saturn ION RedLine Forums
Old 04-23-2012, 11:40 PM
  #36
RooTBeeR's Avatar
Stock cat is a 3" high flow...i need a new cat for my LT. been thinking about just getting a stocker to throw in there if i can make it fit
Old 04-24-2012, 11:50 AM
  #37
Originally Posted by ebristol
thanks ebristol! posting it on here for ease of access. i guess it sounds pretty good!
ZZP 2.5" Cat-back - YouTube!
Old 04-24-2012, 11:51 AM
  #38
you don't always get rasp! plenty of setups have no rasp, hence i was making sure this one didnt! i know, performance>sound but as a daily driver, no rasp>performance
Old 04-24-2012, 12:56 PM
  #39
kdub1492's Avatar
On any set-up you will eventually get rasp. It may not be right away, but it will develop. I have a little rasp at high RPM's but other then that its just a drone sound. I DD mine too, but you eventually get used to it. And I'd rather have my car faster then the next, then care about some rasp at high RPM's. But then again I have a 01 WS6 so I get my muscle and good sound from that lmao
Old 04-24-2012, 03:48 PM
  #40
ebristol's Avatar
That stock muffler has over 130k on it.
Its is a nice setup.
John Powell had a pretty good idea on how to improve it just a little more. Cut off the 2" inlet to the resonator and cut back the resonator until it is 2.5". Then weld in a new 2.5" flange.
I think it would make just enough of a difference to make it worth the effort.
Old 04-24-2012, 11:53 PM
  #41
RooTBeeR's Avatar
[IMG]http://i135.photobucket.com/albums/q134/ericbristol/redline/exhaust/ZZP%20Cat-back/DSC00823.jpg[IMG]
this must be why my zost doesnt seem to have much restriction then...well i actually just replaced the whole res, but same idea
Old 04-25-2012, 06:32 AM
  #42
a_joyner's Avatar
Any gains from switching to the ZZP Catback?
Old 04-25-2012, 07:17 AM
  #43
Administrator
Administrator
Staged07SS's Avatar
I have zero rasp with my setup....
The Corsa resonator does a very nice job cancelling out rasp and drone.
This is the restricitve part in the stock exhaust that people tend to forget about....
To all the people who want to hack up the stock exhaust and add a hi flow muffler, and 2.5" over axle section, make sure you upgrade the resonator as well.
I measured the inlet at 2 1/16" when I removed my stock catback.
Old 04-25-2012, 09:52 AM
  #44
ebristol's Avatar
Max boost went from 22psi on the stock cat-back to 21psi on the ZZP 2.5". Boost is a measure of restriction. So yes the ZZP 2.5" is less restrictive which should provide gains.
Yeah that inlet is tiny! But it matches the outlet of the stock DP. So GM did it for a reason.
Old 04-25-2012, 09:53 AM
  #45
kdub1492's Avatar
Has anyone figured out a decent set-up to go with when cat-less?
Old 04-25-2012, 12:07 PM
  #46
RooTBeeR's Avatar
I am still tempted to try my "custom" corsa idea when I get a chance...
how long is the corsa res again?
Old 04-25-2012, 12:21 PM
  #47
i never measured but i think mine was ~25 inches
Old 04-25-2012, 12:44 PM
  #48
RooTBeeR's Avatar
just the body, or the body and flanges?
Old 04-25-2012, 01:04 PM
  #49
Administrator
Administrator
Staged07SS's Avatar
Yep.
I wish u asked me sooner....
I had the car on the stands the other day installing my new downpipe.
I would have got u an exact measurement.
if u never measured how did u think it was 25"???
Old 04-25-2012, 01:41 PM
  #50
RooTBeeR's Avatar
Yep.
let me check my PM's actually i think i asked you before
...if its short enough i might be able to run 2 resonators and 2 mufflers my wallet might get a little upset but my ears will love me
yeah nevermind, all i have is the muffler part number
Quick Reply: how does zzp longutbe catted sound with stock exhaust?
