How to pull motor?
Old Sep 28, 2009 | 04:32 PM
Wolf117's Avatar
How to pull motor?
So i searched and everything and i cant find a how to of any sort on how to pull the motor. i plan on leaving my tranny in, if anyone could help that would be awesome. i got all the bolts that connect to the tranny i think, took out the motor mount and i cant find where its connected still
Old Sep 28, 2009 | 04:40 PM
thc's Avatar
thc
well the gm build book explains it pretty good for you. you can leave it on the cradle and lower the whole setup out of the car. or do it the hard way.. like i did.. and pull it from the top.
did you get all three trans mounts unbolted?
Old Sep 28, 2009 | 04:42 PM
northvibe's Avatar
you ever pull it before? this may be interesting...
I agree you should read the build book....
Old Sep 28, 2009 | 04:46 PM
Wolf117's Avatar
where can i get a build book? i havent pulled a fwd motor before i just helped my dad do his ls7 in a truck. i have to undo the tranny mounts? i thought they stayed on lol since im leaving the tranny
Old Sep 28, 2009 | 04:49 PM
thc's Avatar
thc
chevy probablly sells the book aswell as a few vendors on this site.
so you want to leave the tranny in the car or on the motor?
if its in the car i dont think you can do that. reason being you need to get the trans input shaft off the motor.
EXsoccer1921's Avatar
http://www.gmtunersource.com/index.p...lsj-build-book
just click the chapter.
Old Sep 28, 2009 | 05:45 PM
northvibe's Avatar
part 1
http://gmperformancedivision.com/con.../23/ecotec.pdf
part 2
http://gmperformancedivision.com/con...tec_Part_2.pdf
part 3
http://gmperformancedivision.com/con...tec_Part_3.pdf
part 4
http://gmperformancedivision.com/con...tec_Part_4.pdf
Old Sep 29, 2009 | 07:01 AM
ralliartist's Avatar
I just dropped the cradle. Super easy.
Old Sep 29, 2009 | 11:40 AM
383_Stroker's Avatar
yeah.. i vote dropping the cradle
Jazer's Avatar
I personally would drop(pull) it all. The Transmission mates onto the engine and the shaft goes into the pressureplate/clutch/flywheel.. which are bolted to the motor. You have to be able to pull them, a good inch or two apart, horizontally so seperate them, before being able to lift the engine out. Getting it out is possible, however you will have ALOT more fun trying to re-mate them when dropping the engine back in.'
In the long run youd be making the job harder on yourself.
Old Sep 29, 2009 | 01:08 PM
selfinfliction's Avatar
we've done this a dozen times or so and the easiest way to do it is to put the car on a lift and drop the entire k-member out the bottom. it takes about 4 hours to drop and swap with 2 people working on it.
Old Sep 29, 2009 | 01:16 PM
Zach06CobaltSC's Avatar
4hrs to drop and swap....that is impressive.
Old Sep 29, 2009 | 01:25 PM
Deathscythe's Avatar
I just pulled mine yesterday, took about 4 hours to do. Loosened the connections and dropped the subframe to get to it.
Old Sep 29, 2009 | 01:30 PM
Are you starting the rebuild now death?
Old Sep 29, 2009 | 01:40 PM
Yeah. I am waiting for the sleeves I need from darton. They haven't released this new profile that they are working on, and I'm not too sure whether or not the sleeves they made for the 2.2 ecotec (02-05) are going to work just the same. I'm pretty sure they do, but I can't afford to make a mistake here.
Old Sep 29, 2009 | 01:43 PM
BennyHHR's Avatar
More like 3 hours....
You were sleeping for the 4th!!
Good luck with the build man!
Old Sep 29, 2009 | 01:57 PM
If that was the case, I would have missed that frozen screwdriver being dropped down your asscrack!
Never forget.
Old Sep 29, 2009 | 04:39 PM
BennyHHR's Avatar
Never forget.
Don't tell Aaron, but paybacks are hell.
Old Sep 30, 2009 | 08:08 AM
not really, there's not that much to do on these cars, a couple of bolts here and there, some plugs and we leave the a/c hooked up to the chasis
we tried with more people one time, but we just kept gettign in each other's way
Solaris99
28
Mar 15, 2017 01:22 PM
Oct 20, 2015 09:56 PM
ThoR294
Oct 4, 2015 08:44 PM
Stuff
Oct 1, 2015 05:47 PM
ThoR294
Sep 28, 2015 05:31 PM
