how to time the engine
Old Apr 11, 2013 | 09:14 AM
robertmichaels's Avatar
I am doing a top end build and NBS. I figured since im using NBS I dont need to worry about timing that chain.
My question is do I need all the specialty tools they use or can someone give me a easier way of doing it.
Old Apr 11, 2013 | 09:17 AM
Tjolley's Avatar
I think there is a how to on here..
It isn't hard.
No special tools required.
Old Apr 11, 2013 | 09:21 AM
09BlueBaltSS's Avatar
I believe the chain has colored marks that correspond with marks on the gears. Having the cam phasers properly clocked will be the toughest part although with no oil pressure I'd imagine they would return to 0* on they're own
Old Apr 11, 2013 | 09:45 AM
kxrida2000's Avatar
Its pretty easy. If u buy the book from autozone it gives a step by step with pics. Just make sure u triple check u have the links right for sure
Old Apr 11, 2013 | 09:51 AM
Staged07SS's Avatar
Administrator
Administrator
Pick up the LSJ build book, and a shop manual.
I just timed my engine after my cam install a few months ago, so everything is fresh in my memory.
If you need any help, shoot me a PM.
Also to answer your question, you do not need the kent moore cam gear bracket like I used, but a kent moore or goodson spring compressor is a must for the valve springs.
No special tools are needed for the timing chain and timing the motor though.
Old Apr 11, 2013 | 09:52 AM
^ good man to deal with. knows his stuffs
Old Apr 11, 2013 | 10:36 AM
the part that got me confused in the build book is where they want you to find the "sweet spot" where you go with .050" lift on either side of TDC. But that seems to be for adjustable cam gears...Is that correct
Old Apr 11, 2013 | 10:39 AM
JapEatr's Avatar
South Central *********
Correct
Old Apr 11, 2013 | 10:40 AM
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by JapEatr
Correct
x2
Old Apr 11, 2013 | 10:45 AM
ok, thats what I thought...
how do i determine where the lobs are supposed to be when I put the cam gears on, or do they only fit into the gear 1 way?
Old Apr 11, 2013 | 11:15 AM
Staged07SS's Avatar
Administrator
Administrator
Non adjustable (stock gears), have tabs that fit into the ends of the cams.
You will see what I mean when you pull them off the stockers.
After installing the gears, you will rotate the cams so the gears (@ TDC) match up with the timing marks on the chain.
Old Apr 11, 2013 | 01:39 PM
ok, I wasnt sure how the cams went on the gears, so if they have a tab, it will be real easy..
here is where I am at
Old Apr 11, 2013 | 01:50 PM
Staged07SS's Avatar
Administrator
Administrator
Nice!!
Yep, they are easy man. They press right into the cams.
Make sure to place a drop of red loctite on the cam gear bolts, and hand start them to hold the gears onto the cam.
Old Apr 11, 2013 | 02:00 PM
mrbelvedere's Avatar
1. we don't have phasers in the lsj
2. on the lnf the phasers don't clock the engine times like an lsj
3. know what you talking about before you post
Old Apr 11, 2013 | 03:08 PM
kxrida2000's Avatar
Id recommend blue loc tite. Red is a giant ***** to break loose haha
Old Apr 11, 2013 | 07:40 PM
pfffffffft it is not near as bad as your making it out to be
Old Apr 12, 2013 | 07:08 AM
Staged07SS's Avatar
Administrator
Administrator
True dat!!
Old Apr 12, 2013 | 10:05 AM
kxrida2000's Avatar
It is when blue does the trick haha
Old Apr 12, 2013 | 10:17 AM
Staged07SS's Avatar
Administrator
Administrator
Meh, I never had an issue with the red stuff.... I'll stick with what works for me
Old May 9, 2013 | 03:13 AM
Do I need to time the neutral balance shafts, I figured not because the water pump shouldn't have to be in time with anything
Old May 9, 2013 | 04:09 AM
c130aviator's Avatar
nope, no timing needed on that waterpump/nbs chain. stick on, bolt up the tensioner, pull the pin.
I use red loctite on everything too. Just got to get a longer cheater pipe.
Old May 9, 2013 | 07:11 AM
Staged07SS's Avatar
Administrator
Administrator
Or more elbow grease
Old May 9, 2013 | 07:23 AM
and the new hydraulic tensioner for the cam chain doesn't need any setting, just bolt in place and go correct?
Old May 9, 2013 | 07:24 AM
Staged07SS's Avatar
Administrator
Administrator
Correct.
Old May 9, 2013 | 10:20 AM
Texas SS's Avatar
Good info
