how to time the engine
I am doing a top end build and NBS. I figured since im using NBS I dont need to worry about timing that chain.
My question is do I need all the specialty tools they use or can someone give me a easier way of doing it.
I believe the chain has colored marks that correspond with marks on the gears. Having the cam phasers properly clocked will be the toughest part although with no oil pressure I'd imagine they would return to 0* on they're own
Pick up the LSJ build book, and a shop manual.
I just timed my engine after my cam install a few months ago, so everything is fresh in my memory.
If you need any help, shoot me a PM.
Also to answer your question, you do not need the kent moore cam gear bracket like I used, but a kent moore or goodson spring compressor is a must for the valve springs.
No special tools are needed for the timing chain and timing the motor though.
the part that got me confused in the build book is where they want you to find the "sweet spot" where you go with .050" lift on either side of TDC. But that seems to be for adjustable cam gears...Is that correct
You will see what I mean when you pull them off the stockers.
After installing the gears, you will rotate the cams so the gears (@ TDC) match up with the timing marks on the chain.
Yep, they are easy man. They press right into the cams.
Make sure to place a drop of red loctite on the cam gear bolts, and hand start them to hold the gears onto the cam.
2. on the lnf the phasers don't clock the engine times like an lsj
3. know what you talking about before you post
I use red loctite on everything too. Just got to get a longer cheater pipe.
