HP gain?
Old Jun 22, 2008 | 02:37 AM
reign1's Avatar
HP gain?
new....sorry...havent looked at all the threads.
by word of mouth i heard just running an after market cat back would increase the horsepower. and that you need the back pressure. then i heard from others that technically you can cut straight down pipes and run it that way because you dont need back pressure considering the supercharger on the 06. i still have the warranty and everything so i dont want to chop anything yet. but i am kind of confused on who to believe......
oh and is it normal to lose almost 4 miles to the gallon with an AEM intake?(electronically lost, not road tested) just dropped the cold air but not after market cat back yet.....
Old Jun 22, 2008 | 02:42 AM
shsballa023's Avatar
Go gmpp catback, its got proven gains of 12hp I believe. As far as cold air intake, just disconnect ur battery for about 10 minutes and reconnect. Should be good to go, also check to make sure everything is installed correctly, fittings are good that kind of stuff. And welcome to the site
Old Jun 22, 2008 | 02:46 AM
reign1's Avatar
ohh and btw i found out that my car weighs more than my friends 350 z and my friends 88 camaro. damnit.....anything to gut?
Old Jun 22, 2008 | 12:21 PM
flash13brandon's Avatar
just FYI...the 350s weigh over 3k lb so I dont think yours weighs more than his
Old Jun 22, 2008 | 12:27 PM
jwolf8604's Avatar
Interested to see how this one plays out...I gotta hunch
BUT, just in case you're serious. the 350Z weighs around 3500 and our cars weigh right at 300. So your buddy was wrong. You will gain hp and lose backpressure with an aftermarket exhaust and no...YOU SHOULD NOT LOSE MPG WITH AN INTAKE. It should increase it up to 10%. 30 mpg then you should start seeing around 32-34 mpg
Old Jun 22, 2008 | 08:14 PM
reign1's Avatar
ok well that guy just kind of stabbed me in the back last night so f*ck him. whatever. thanks for the heads up.
Oct 13, 2015 09:32 PM
Builttss
Oct 4, 2015 10:21 AM
goaliemo
Sep 28, 2015 01:37 PM
allpro666
Sep 24, 2015 04:42 PM
roadrunner132
Sep 16, 2015 09:13 AM
