iat's to worry about?
Old Mar 21, 2011 | 01:01 PM
ty07scss's Avatar
Yes or no...?
My iat at wot was 160 degrees when it was 75 degrees out. This is something to worry about? And possible solution besides faulty intercooler pump? And after I get home ill do the classic "hit it with a hammer to see if it solves the problem....any other causes to it beng so high?
Should I be worried yes or no?
Thanks guys
Old Mar 21, 2011 | 01:02 PM
DEZZIE41's Avatar
mine runs usually no higher then 90-95
Old Mar 21, 2011 | 01:03 PM
nizzle's Avatar
160 is not too bad if you're REALLY goin hard but it should be quite a bit lower. Did it go down any after you started driving normal again? If so, down to what temp?
CTcar's Avatar
Sounds like a busted pump, what are your mods? Under normal driving mine is about 20-30 degrees higher then outside temp
Old Mar 21, 2011 | 01:07 PM
SSJit's Avatar
Take the cap off the IC Pump reservoir, start your car and see if you see coolant running thru the bottom of the reservoir. What size pulley are you running? I have a 2.6" pulley and I was logging iat temps at 204 when my IC pump went out..
Old Mar 21, 2011 | 01:09 PM
nizzle's Avatar
Not sure about other years but my ic pump doesnt turn on unless the engine is under a slight load. Kinda hard to check without a scan gauge or running your own power to the pump to check it.
Old Mar 21, 2011 | 01:10 PM
nizzle's Avatar
Very possible it's a bad pump tho. That is a very common part to replace on our cars.
Old Mar 21, 2011 | 01:11 PM
DEZZIE41's Avatar
truth be told i unno **** bout iats lol...just when it goes round 120 and high im like wtf
Old Mar 21, 2011 | 01:20 PM
nizzle's Avatar
normal driving bout 20 degrees higher than oustide temps. Runnnig hard, depends on the the temps outside but should be no more than 120 maybe 130 TOPS.
Old Mar 21, 2011 | 01:22 PM
DEZZIE41's Avatar
i did a wot pull the other day and it went ot 90 then i drove aorund went to get coffee tunred off car for ten min came back out and the iats were reading 199 after i turned the car back on?
Old Mar 21, 2011 | 01:26 PM
nizzle's Avatar
thats because the pump doesnt run all the time. Usually only when the engine is under a slight load. Next time temps get that high, drive around normal for a while and see if they drop. They should drop WAY down.
Old Mar 21, 2011 | 01:27 PM
DEZZIE41's Avatar
ok kool thanks im still new to this and just got tuned so i dont want nothing to go boom lol...srry for the thread jack
Old Mar 21, 2011 | 01:30 PM
nizzle's Avatar
A nice tip I dont always tell people is use a 60% water 40% coolant mix with water wetter for your ic fluid. It works GREAT! Unless you live in an area that drops down to like 0 degrees F or something.
Old Mar 21, 2011 | 01:31 PM
DEZZIE41's Avatar
our winters get like -20c im running a 50/50 mix
Old Mar 21, 2011 | 01:32 PM
srt-10's Avatar
160* is abit high, i was hitting 145* after 3 pulls on the highway with 30*C temps and i was running the tvs, meth, h/e, 1 step colder plugs, cai. My timing was 25*...so if i was that advanced in timing and only hitting 145*, then id say something is wrong.
Old Mar 21, 2011 | 01:35 PM
nizzle's Avatar
-20c?! DAMN I feel sorry for you.
Old Mar 21, 2011 | 01:37 PM
troyss's Avatar
I thought the IC pump always runs when the car is on
Old Mar 21, 2011 | 01:41 PM
nizzle's Avatar
In most other cars yes. In our cars no. I wish it did run all the time. I am gonna put mine on a toggle so it will work like it does stock but I can turn it on at anytime.
Old Mar 21, 2011 | 01:44 PM
srt-10's Avatar
dont feel sorry for him, it hit -59*C here last year..lol.
Old Mar 21, 2011 | 01:45 PM
nizzle's Avatar
HOLY ****! That's nuts!
Old Mar 21, 2011 | 01:47 PM
troyss's Avatar
Why does eveyone say that to check the IC pump turn the car on and within 10 seconds you should see the coolant flow? I heard that thery over 50 times.
So when does the IC turn on. What degree temps? When does the computer know when?
Old Mar 21, 2011 | 01:50 PM
nizzle's Avatar
It is boost/vacuum triggered. When you engine starts to have a load put on it, the pump kicks on.
Old Mar 21, 2011 | 01:53 PM
troyss's Avatar
So it does still kick on even when its not under strain?
Old Mar 21, 2011 | 01:55 PM
nizzle's Avatar
No
Old Mar 21, 2011 | 01:56 PM
troyss's Avatar
Also is there a way to put a switch on it to keep it always running when driving?
Zzp says there 60% of ss/sc drivers running a bad pump and don't even know it.
