iat's to worry about?
Old Mar 21, 2011 | 02:01 PM
sundevil07's Avatar
Nizzle you have no idea what you're talking about. The pump comes on after ten seconds of the car being started on the stock tune and gm tunes. It's not a progressive pump
RooTBeeR's Avatar
Originally Posted by nizzle
It is boost/vacuum triggered. When you engine starts to have a load put on it, the pump kicks on.
IC pump is always on
Old Mar 21, 2011 | 02:02 PM
nizzle's Avatar
Not true for the 07 SC atleast. I know that for a fact!
Old Mar 21, 2011 | 02:04 PM
nizzle's Avatar
Maybe for the turbo idk, but not for the SC! I am 100% sure. I have check it on mine.
Old Mar 21, 2011 | 02:05 PM
RooTBeeR's Avatar
dude, i have and 07 sc...
Old Mar 21, 2011 | 02:06 PM
nizzle's Avatar
Originally Posted by troyss
Also is there a way to put a switch on it to keep it always running when driving?
Zzp says there 60% of ss/sc drivers running a bad pump and don't even know it.
60% running bad pump I believe. They crap out all the time.
sundevil07's Avatar
And dude I had an 06, turbo models don't have an ic pump. You need a new pump as well it seems hahaha
Old Mar 21, 2011 | 02:07 PM
troyss's Avatar
Nizzle do you know what your talkn about?
The tc balts don't even have an IC pump. Im sure the pump always runs
Old Mar 21, 2011 | 02:08 PM
Staged07SS's Avatar
Administrator
Administrator
As do I, and you're right.
The pump turns on after 10sec, and stays on.
nizzle's Avatar
I have check it more than once. With a volt meter, light tester, scan gauge, and trying to just listen for it. Maybe if your rpms are up due to converter warm up cycle but not once it is up to operating temps.
Old Mar 21, 2011 | 02:09 PM
  #36
RooTBeeR's Avatar
I just screen shot this from HP Tuners from my stock tune file...
Engine Run Time: Minimum 10 Seconds before the pump turns on
Intake Air Temperature: Minimum 5 Degrees Fahrenheit(if IAT1 drops lower than 5*F the pump will turn off, any temp above 5*F it will be on)
  #37
05SSBalt's Avatar
Sorry guys but Ive been trying to figure out exactly wut you guys have been talking about but can someone clariffy some things for me? Is iat-intercooler air temp? and I noticed the coolant temp in my information center that reads around 180-187 for the engine coolant so where are you guys seeing a temp gauge for the intercooler air temp? Ive heard its not supposed to be over 130 and I would like to check mine. Thanks
Old Mar 21, 2011 | 02:10 PM
  #38
nizzle's Avatar
I disagree.
  #39
RooTBeeR's Avatar
you can see the coolant moving and can hear the pump running IF you have a properly working pump...
Old Mar 21, 2011 | 02:12 PM
  #40
nizzle's Avatar
But IAT1 is pre supercharger temp. IAT2 is after supercharger.
Old Mar 21, 2011 | 02:13 PM
  #41
RooTBeeR's Avatar
IAT : Intake Air Temp
For IAT's to be read, you need either HP Tuners, or an Areoforce Interceptor, or some sort of OBDII Scan gauge
  #42
nizzle's Avatar
My pump is brand new. Just put it in about a month ago. It is working fine. My IAT2's hover around 20* above IAT1 unless I am stomping on it.
Old Mar 21, 2011 | 02:15 PM
  #43
Staged07SS's Avatar
Administrator
Administrator
I disagree.
That's fine, but you're still wrong.
Grab your hoses while the car is idling. You will feel the coolant pump through the system.
Old Mar 21, 2011 | 02:16 PM
  #44
nizzle's Avatar
I will have do get a vid of mine some how. I would like you to do the same but know that is a steep request
Old Mar 21, 2011 | 02:17 PM
  #45
RooTBeeR's Avatar
whats your point?
acutally tbh i dont know which iat it actually reads off of, but if its iat2 that has to be lower than 5*F than your pump will be on even more often then iat1...
and unless your weather is constantly under 5* that is null and void
Old Mar 21, 2011 | 02:18 PM
  #46
nizzle's Avatar
whats your point?
My point is tbb, that I might be right and you might be wrong given the fact you dont know the dif between IAT1 and IAT2
Old Mar 21, 2011 | 02:21 PM
  #47
Staged07SS's Avatar
Administrator
Administrator
I have opt b. All you will see is a few burps as it bleeds the air when the pump first turns on.
You need to go grab the lines as your car idles. You will feel the coolant circulating trust me. It would be a very poor cooling system if it didnt circulate the coolant all the time.
Old Mar 21, 2011 | 02:22 PM
  #48
RooTBeeR's Avatar
damn, now i remember why I dont come over to .nub much anymore
Old Mar 21, 2011 | 02:24 PM
  #49
nizzle's Avatar
That's what I thought to but then I proved myself wrong, unfortunately. I dont want it to be like this. I wish it was on all the time.
  #50
RooTBeeR's Avatar
yeah i got opt. b, dual pass, stock pump, stock h/e(used to have a small cx racing, sold it to help save for the griffin )
