IC pump?
Old Jul 7, 2012 | 11:18 AM
rwperlaki's Avatar
IC pump?
So I been told that the IC pump is known for going bad and with the miles on my SS/SC (108000) that I should check and make sure it's still working. So my question is how do you tell that its running. With the car running. I pulled the cap off to see if coolant was flowing threw the tubes and nothing. I also put my hand on the pump to see if it felt like it was running and nothing. I also opened the bleeder on the IC to see if the pump will push fluid out and still nothing. So my guess is the pump is not working. Can any one give me any info on how the pump works. Is it supposed to run all the time or shut on and off.
Old Jul 7, 2012 | 11:58 AM
nhanson's Avatar
Pump will run when the car is running.
You could try hitting the pump with a hammer and see if it starts.
2 things you could do either open pump up and clean the brushes out (my buddy did this and his is still working for a while now) or buy a new pump.
When pump is running coolant will flow in the fill tube.
Old Jul 7, 2012 | 12:00 PM
reduf99's Avatar
sjc0013 Licks windows
^^^^ exactly
Old Jul 7, 2012 | 12:20 PM
rwperlaki's Avatar
Ok thanx so much ill try this out with this hot heat out side (107) my SS has been really sluggish in low rpm's
Old Jul 7, 2012 | 12:44 PM
rwperlaki's Avatar
Yep I went out there and hit it lightly with a hammer and sure enofe it kicked on
Old Jul 7, 2012 | 01:45 PM
bluebalt07's Avatar
You are still going to want to at least pull it apart to clean it out or replace it. If you had to hit it to make it run, it's bound to quit again and when it's this hot you don't want that happening. That's why your car has felt sluggish, your IAT2's have probably been sky high in this heat.
Old Jul 7, 2012 | 01:58 PM
nhanson's Avatar
Feels sluggish from heat and it pulls timing
Old Jul 7, 2012 | 03:05 PM
rwperlaki's Avatar
Well I think I'm going to try cleaning it. I just had to buy a new TB so I'm a little low on funds. I hope it last just a few weeks longer
Old Jul 7, 2012 | 03:21 PM
zrated89's Avatar
the brushes wear down cleaning it out is about as permanent of a fix as the hammer is. Either replace the brushes or the pump period
Old Jul 7, 2012 | 04:03 PM
rwperlaki's Avatar
Where is a good place to get the brushes. I might just replace them if I can get them
Old Jul 8, 2012 | 09:38 AM
blackjack232's Avatar
unless your savvy about it would just go ahead and replace the pump, 100$ from ZZP gets you one. a bosch one, probably less at a general parts store. you also run the risk of F****** your pump up and needing it replaced anyways.
DarrenGC
Dec 24, 2021 01:55 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
