IC Pump Question
Old Sep 23, 2010 | 01:03 AM
PenguinPIE's Avatar
IC Pump Question
does the IC pump turn on as long as the engine is on and does not depend on the temperature and stuff?
the reason im asking is that, i took my car in b/c i dont see any flow at the filler neck and while i was showing that to the service rep at GM while the car is running, the pump suddenly turns on. he told me the pump will only turn on when its hot enough, is that true?
Old Sep 23, 2010 | 01:02 PM
PenguinPIE's Avatar
bump...
Old Sep 23, 2010 | 01:44 PM
CarsonTech's Avatar
Thats not true. It runs all the time as long as the car is running. There is a 10 or 12 second delay for it to turn on when you start the car. The start up delay can be changed in the tune.
Old Sep 23, 2010 | 02:01 PM
Staged07SS's Avatar
Administrator
Administrator
^This.
Old Sep 23, 2010 | 02:17 PM
scotch89's Avatar
does anyone now if the pump flows more when ur pushing the gas pedal? ive noticed my IAT2 go up if im not on the gas, just coasting
Old Sep 24, 2010 | 11:19 AM
CarsonTech's Avatar
It should flow just the same. Although the faster you turn the engine, the more potential your alternator has for producing more voltage. That may have a tiny affect on the voltage going to the pump, but nothing noticeable.
What you’re experiencing is not much air passing through the TB when coasting, because the blade is almost shut. Also, keep in mind, if you are not moving fast enough, there is not much air being shoved across the heat exchanger fins, which is also needed to cool the coolant down in the heat exchanger system. This is why, at idle, the IAT2 temp starts to go up. When you start moving, your temps go down because you are pushing air through the HE and also sucking more air across the cooled parts in the IM.
Old Sep 24, 2010 | 11:28 AM
Staged07SS's Avatar
Administrator
Administrator
That's because when you push on the gas you are letting more air enter your intake manifold thus cooling your intake charge (as long as youre out of boost).
Old Sep 26, 2010 | 12:44 AM
SunburstSS's Avatar
my iat2's drop down when im in boost guess why lol
Old Sep 26, 2010 | 12:48 AM
PenguinPIE's Avatar
meth?
Old Sep 26, 2010 | 12:51 AM
SunburstSS's Avatar
Originally Posted by PenguinPIE
meth?
correct sir gotta love it...
Old Sep 26, 2010 | 01:00 AM
PenguinPIE's Avatar
haha stop tempting me
i still gotta sort out everything for my stage 3 install first
Old Sep 26, 2010 | 01:23 AM
SunburstSS's Avatar
Talking
lol dude it took me a year to get to this level lol, i cant waiti to get it tuned and dynod but yeah i invested in cooling mods 1st meth was unfortunatly the last coz i didnt believe in its potential at 1st but now im in love with it haha
Old Sep 26, 2010 | 01:38 AM
Karlen89's Avatar
You'll hate it when you run out...
Old Sep 27, 2010 | 10:43 AM
StageII07's Avatar
My AITs stay high no matter what...due to my ic pump not working...thank god im putting a new one in..along with fixing my leaking coolant prob ha..
Old Oct 2, 2010 | 05:00 PM
PenguinPIE's Avatar
I also noticed that the coolant disappears everytime I check, but the coolant level pops back up a little but when I unscrew the cap. Does anyone know what's causing that?
Old Oct 2, 2010 | 08:20 PM
mrbelvedere's Avatar
it is pressurizing and compressing the air in the system when all the air is out it should stop doing that
Old Oct 2, 2010 | 11:07 PM
PenguinPIE's Avatar
so does that mean i should add more coolant? coz when it is pressurized it looks like there is nothing in the system. but when i unscrew it sometimes it goes up to half of the fill neck :S
Old Oct 10, 2010 | 05:21 PM
PenguinPIE's Avatar
i'm quite sure that my pump is only working once in a while. is the pump part of the powertrain warranty?
Old Oct 11, 2010 | 10:28 AM
JERMzSS's Avatar
nope its not, dont buy one at the dealership they will rip you a new one.
heres where I got my new one from. low price and fast free shipping.
2003-2004 Mustang Cobra Lightning Intercooler Pump - Cooling - Engine Compartment - Home for your Ford Mustang
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
roth
Sep 26, 2015 12:16 PM
