ID1000 who is running them
Old Sep 23, 2012 | 12:39 PM
slvr 04 rl's Avatar
i installed these yesterday on my turbo swapped lsj. but it appears they are a bit longer than the 80lbs i had. did you guys have to do anything special to make them fit because the o rings are going past the injector cups and not sure if its causing my problems cause they car misfires on every cylinder at about 4k rpms. the car drives and idles just fine, only until i go WOT.
i have a 2004 saturn ion redline also if it makes a differnce..
Old Sep 23, 2012 | 12:43 PM
carstedt's Avatar
mine run just fine with no issues, your using the purple adapters that come with them correct?
Old Sep 23, 2012 | 12:46 PM
ItalianJoe1's Avatar
Length should be very similar. If you were having issues they would be leaking air all the time. Your tune is off if it's only a WOT thing.
Old Sep 23, 2012 | 12:59 PM
slvr 04 rl's Avatar
When I ordered them I got the ones for my model vehicle
That's what we are working on. But it's like you can set them in and put the rail on. You can see they are in right and then I go make one pass and its like it sucks them into that cup. I'm going to go try another tune right now.
Old Sep 24, 2012 | 01:41 AM
InfraRedline's Avatar
I sent Kendall a pic of mine. That should help.
Old Sep 24, 2012 | 10:50 AM
slvr 04 rl's Avatar
yeah, he sent it to me, now i just need to pull them out and set it up like that. thank you.
Old Apr 24, 2013 | 09:19 PM
advise's Avatar
Reviving this thread
What was the fix for this seems like my #2 injector is leaking
Old Apr 25, 2013 | 09:54 PM
slvr 04 rl's Avatar
a larger o-ring to go over the whole injector and so itll seal in those plastic cups. its been working fine for me lately, this was nothing to do with the tune.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
tomj77
Oct 4, 2015 11:39 AM
dieGone
Oct 1, 2015 06:27 PM
Extremespeed
Sep 29, 2015 04:34 AM
