ideal vacuum supercharged?
Old Jul 17, 2013 | 11:37 PM
Bass_Waves's Avatar
Before I got a new head put on the car. My vacuum read 20-21 pounds mercury. Or -20 to -21. After I got the new head it reads -18 at idle and at operating temps. Currently its only got GMs2. Stock everything except cat back.
When I was at -20 I had full bolt on gm 2.
Is it possible I have an unhealthy engine now with the new head on? Could the hosing be causing this issue? Car feels slower than before. But I saw close to 14~ pounds of boost on wot. Its not the same as before I feel it pull.
Old Jul 18, 2013 | 07:25 AM
TStone's Avatar
Is it an lsj head? Ported? Double check your hoses. Make sure nothing is worn out.
But the "general rule" is 18-21"
Old Jul 18, 2013 | 07:27 AM
Bass_Waves's Avatar
I believe it is. Dealer put it on. Bolts right up. I used the aero force and I'm actually at -17.1 to -17.6. Imma replace all hoses that deal with vacuum on the car. Any major hose I should worry for that has direct correlation to my concern ?
Old Jul 18, 2013 | 07:33 AM
Staged07SS's Avatar
Administrator
Administrator
Here's a nice read on vacuum readings:
Tips on Reading Gauges: Vacuum Gauges
Old Jul 18, 2013 | 07:39 AM
TStone's Avatar
Make sure the one coming off the top of the manifold is good. It's right In front of the fuel rail. Also make sure your intake seals up fine, and the tb
Old Jul 18, 2013 | 08:30 AM
ideally it should stay at -20, and i noticed when my air conditioning is on it goes up a bit to like -19, -18
Old Jul 18, 2013 | 09:06 AM
Staged07SS's Avatar
Administrator
Administrator
Elevation plays into this as well.
Just like when trying to compare boost numbers you can only give a range.
You can't say it "should" stay at -20, because a perfectly healthy car might be at -18 but at a higher elevation (just giving an example fyi, not intended to be a jab against u man). Also, you are correct about the a/c. I notice the same thing.
My car is usually around -16, but I have aftermarket cams, which also plays into idle vacuum. Too many variables. That's why I posted that link. It's a nice read.
Old Jul 18, 2013 | 12:08 PM
Bass_Waves's Avatar
I started going off by my interceptor. On idle. 750 rpm average. I get 17.3 to 17.6 inches vacuum.
Old Jul 18, 2013 | 12:49 PM
Staged07SS's Avatar
Administrator
Administrator
That's fine man.
Old Jul 18, 2013 | 12:57 PM
chris88z24's Avatar
Perfectly normal.
Old Jul 18, 2013 | 01:50 PM
Bass_Waves's Avatar
That's with the ac off. Before the new head it was 20-21. Ac off.
Old Jul 18, 2013 | 01:58 PM
Staged07SS's Avatar
Administrator
Administrator
When did you take those readings?
Same location, elevation, temp as the new ones?
Old Jul 18, 2013 | 02:40 PM
Bass_Waves's Avatar
Yeah my driveway. Only diff is the heat from outside.
Unless this heat wave plays a roll in it, I'll find out in a few months how it is.
Last edited by Bass_Waves; Jul 18, 2013 at 02:40 PM. Reason: Automerged Doublepost
Old Jul 18, 2013 | 02:50 PM
Staged07SS's Avatar
Administrator
Administrator
Air density can def alter readings.
Regardless, you are still in the acceptable range of good vacuum and a healthy engine.
Old Jul 18, 2013 | 03:02 PM
Bass_Waves's Avatar
OK. That's all I kinda need to know.
This way I can start to mod it again. Was hopping to go turbo but it may be on hold. Gonna push my blower for time being. Love the power curve
Old Jul 18, 2013 | 03:18 PM
I was getting so offended until you told me it wasn't a jab
Old Jul 19, 2013 | 07:07 AM
Staged07SS's Avatar
Administrator
Administrator
Yes sir!!
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
OrangeCoba
Oct 1, 2015 10:00 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
