Idle problem CURE!!!!!!!! Finally!!
Old Feb 23, 2014 | 09:40 AM
  #476
neumannl001's Avatar
Thanks for the reminder!!!
Mine only does it in the summer. Mostly during triple digit weather.
Gotta another problem and have been searching for answers to no avail. I got the Vibrant Oxygen Sensor Defouler and had my mechanic put it on during and oil change. He told me the 02 sensor wire would be too short to reach the defouler once it was installed. Is he wrong??? Coz No One Else in the threads I read said they had this issue.
Old Mar 12, 2014 | 11:43 AM
  #477
Lance989's Avatar
Originally Posted by Coblt ss super
pretty much, i changed a bunch of things before hand and then i cleaned the MAF sensor and strted to work a little better so i decided to buy a new one and i did and when i installed it, it ran like new again
I ended up having to do the same thing. Cleaning the TB and MAF sensor with MAF cleaner helped like a charm but it was still acting up. I ended up replacing the sensor and fuel filter now she purs like a kitten.
Old Apr 30, 2014 | 10:41 PM
  #478
gbpackrfan04's Avatar
so glad I found this, it was annoying the hell out of me!
quick and easy fix.
Old Apr 30, 2014 | 11:06 PM
  #479
Joe09SS's Avatar
If you guys have replaced the MAF, which brand have you gone with?
Old Apr 30, 2014 | 11:24 PM
  #480
chris88z24's Avatar
Anyone else's LSJ have a lopey idle?
Old May 24, 2014 | 10:00 AM
  #481
ss-06/1ap37's Avatar
I had the same problem few months back and i found out bout cleaning the TB by reading the threads on hear it def. Fix the problem but it still flutters when ac is on so im not sure what thats from. Got my car 3 months ago and it had all the common problems today its the rear calipers leaking lol but i love my car regardless
Old May 27, 2014 | 11:56 PM
  #482
KyleW1992's Avatar
i know this is a super old post but im having the exact same issue as whats been posted, but im also getting a missfire code, would this cause that?
Old Jun 18, 2014 | 12:22 PM
  #483
MrSlickSter06SS's Avatar
Are you running a Cold Air Intake?, and if so which one?
Old Aug 7, 2014 | 09:31 AM
  #484
Lucid Dreams94's Avatar
Please help me!!! I cant figure out what the problem is with my 2007 LSJ SC
So I'm having a problem with my car at*idle*and WOT. I normally run 16.5psi at WOT and I am only pushing between 4-5psi at the moment. At idle I'm leaning out and misfiring randomly on all cylinders. I changed the*MAP*Sensor because it was faulty and it didn't fix the problem. I changed the bypass valve hoses and its not leaking from there. Idk what it could be. Any ideas?
Old Aug 17, 2014 | 12:33 PM
  #485
Thanks Everyone!
I am one of the many who need to clean my TB and gotta have instructions...
Old Aug 17, 2014 | 07:59 PM
  #486
DarkGothic's Avatar
I'm having the same loping idle with mine, but it stalls out after running a couple minutes and when i hit the gas. I cleaned my TB (which was dirty) but that didnt seem to help the issue. Its not throwing codes and I have no idea what is going on. I am a mechanic and work on it at the shop i work at and I've tried everything i can think of but I can't get it right. any thoughts?
Old Aug 21, 2014 | 10:19 PM
  #487
Getaway_Driver's Avatar
Is it possible that someone link me to a video or at least pics of a How-To for this? Would greatly appreciate it. If it's already been posted in this thread, sorry. Just don't have time to search through 20 pages of posts for it.
Old Aug 22, 2014 | 01:46 AM
  #488
andrewcarr1993's Avatar
Unbolt intake pipe, disconnect clip for the throttle body, unscrew throttle body, hold open after spraying with throttle body cleaner and wipe out all the gunk you can, that's really it besides bolting it back on and making sure you connect it.
Old Aug 23, 2014 | 12:03 AM
  #489
Problem is I'm not mechanically inclined, so I'd have to find out how to unbolt the intake pipe and disconnect the throttle body.
I know, I know..
Would appreciate video or pics if anyone has any.
Old Aug 23, 2014 | 07:31 AM
  #490
BARON420's Avatar
maintenance people ! sc people especially. I clean my TB every spring / fall
remove air intake tube use throttle body cleaner and a toothbrush
holding throttle plate open
this only cures hunting idle
Old Aug 23, 2014 | 09:03 AM
  #491
umrdyldo's Avatar
I know, I know..
At 70k my throttle body on the SS/TC was pretty clean. I wouldn't worry about it. My LS was much worse at 50k.
Old Aug 23, 2014 | 11:04 AM
  #492
I'm well beyond 115k at this point. lol
I'm tired of paying for maintenance work at stealerships & shops, so I'm trying to learn to do this on my own. My car refuses to kick into boost in 1st gear, and I'm assuming it has to be a dirty throttle body that's doing me in.
Old Aug 23, 2014 | 05:20 PM
  #493
T-fog's Avatar
Getaway driver-
This is a decent video on what you could do...The only reason some people see this as an issue is because you are pushing the carbon deposits into the engine.
But if you get a routine like... me and Baron420... then this way will work good for you since it shouldn't be that dirty since you stay on top of it.
Old Sep 9, 2014 | 12:49 PM
  #494
thebr0ken's Avatar
I was having the idle bouncing issue as well and cleaning out the TB worked. It smoothed it out greatly, unless I want to use the A/C. Before it would almost stall, now it doesn't stall but still a 600-1500RPM bounce when I get to a stop. Loud as hell exhaust just exaggerates the idle bounce sound. I bought the car used and have no idea what was done to it, but whomever had it, spent some money on it. It has a 2.8 pulley so I assume different injectors would be needed, but cant verify atm if they are different. I plan on getting numbers off of them to see. It does have a cold air intake but I don't know who's. That is the only thing that really bothers me, well besides the high rise spoiler flapping away as I drive.
Old Nov 1, 2014 | 07:13 PM
  #495
RA080424's Avatar
Did this today and totally fixed the issue on my LSJ. I am having a higher than normal idle now but that should eventually go away. THANKS!
Old Dec 16, 2014 | 05:12 PM
  #496
thebr0ken's Avatar
I cleaned out the throttle body and the only thing it gave me was a cleaner tb. It helped a little, but its especially noticeable now that its cold. It surges up and down till it warms up a bit, then it settles
Old Jan 2, 2015 | 06:14 PM
  #497
papageorgio's Avatar
Mine would
Mine would do the idle bounce in the cold (would sometimes even opush it into reduced power mode) but would be fine once the car warmed up, cleaned the TB out and haven't had a problem since
Old Feb 23, 2015 | 10:14 PM
  #498
KTM's Avatar
KTM
Was bored today, so decided to pull my Throttle body off. Cleaned it up, started her up and idle was perfect. =p
Old Mar 17, 2015 | 01:31 PM
  #499
mprech's Avatar
Just wanted to say thanks for posting this! The bouncing idle was driving my crazy! Not to mention stalling out every time I stopped... Worked like a charm though!
Old May 14, 2015 | 10:36 PM
  #500
PotatoLvrd's Avatar
So I have the same issue with my 07 ss.
I am going to do this tomorrow but i am also getting a p1101 code bank 1 too rich. could this be the issue as well??
