Im In Bigggg Trouble
Old Feb 23, 2009 | 10:43 AM
blackss2.0's Avatar
While removing the stock pulley I used the pulley puller wrong because it was used and had no directions and i got the pulley puller shaft stuck inside the blower shaft. What should i do????
Old Feb 23, 2009 | 10:45 AM
PhantomSS's Avatar
if u already pulled the pulley do what i did if ur too lazy to go to napa.
block of wood + hammer
Old Feb 23, 2009 | 10:46 AM
ShortStack's Avatar
the shaft is threaded, have you tried twisting it out?
Killa SS's Avatar
sit down, press on the supercharger with ur feet, and pull that SOB. be a man. lol
Old Feb 23, 2009 | 10:47 AM
PhantomSS's Avatar
lol.
Old Feb 23, 2009 | 11:45 AM
blackss2.0's Avatar
I even pu that **** in a vice and pulled with plyers as hard as I could.
Old Feb 23, 2009 | 11:47 AM
ShortStack's Avatar
dont pull, twist...
the inside of the shaft is threaded.
Old Feb 23, 2009 | 11:51 AM
blackss2.0's Avatar
I cant twist because the pulley is off and there is nothing to hold the supercharger shaft still when i twist.
Old Feb 23, 2009 | 11:54 AM
ShortStack's Avatar
Well... thats how its going to come off...
i dont know what tools you have on hand, but im sure you can find a way to try to twist it off.
Old Feb 23, 2009 | 12:01 PM
LamboW9's Avatar
put a rag in between the rotor blades and put a wrench in there thats wrapped with rags, then you can spin the thread without the supercharger spinning
Old Feb 23, 2009 | 12:05 PM
ShortStack's Avatar
you would just have to be very careful doing that.. but thats probly the best way.
Old Feb 23, 2009 | 12:06 PM
Psykostevo's Avatar
Get a rod and shove it in the rotors carefully, have a friend hold it. If you don't have friends.......then why are you on this site.
That will stop the freespin of the shaft.
Old Feb 23, 2009 | 12:11 PM
PhantomSS's Avatar
just got back but this is the best solution since you didnt break the set screw totally inside of the snout.
Old Feb 23, 2009 | 12:35 PM
TRANSAM197781's Avatar
couldnt you just put a washer against the snout then run a nut on there then another nut to lock the first one down and use the first one as leverage to back the rod out
Old Feb 23, 2009 | 12:41 PM
PhantomSS's Avatar
wow even better.
least u didnt do like me, i broke the set screw about 1/4 inside of the snout. only way to fix it was to take it to a machine shop....
Old Feb 23, 2009 | 12:48 PM
just throwing out suggestions i know how fustating those situations can be
Old Feb 23, 2009 | 01:57 PM
blackss2.0's Avatar
Well i brought it to some guy that works out of his garage. He said it was possible that the supercharger shaft would crack from him taking out the tool shaft out because there could possibly be a hair line fracture in the shaft from me already trying to get it out. Just got a call from him and he got it out but its gonna cost me 150 bucks.
Ill letyou guys know later how he got it out without damaging the shaft.
Last edited by blackss2.0; Feb 23, 2009 at 01:57 PM. Reason: Automerged Doublepost
Old Feb 23, 2009 | 02:00 PM
daythecountrydied21's Avatar
lol should've just bought a new blower for that price
WhineSSbaby
Sep 1, 2020 12:39 PM
Bluelightning
Nov 11, 2015 02:41 PM
matthewwalsh1994@gma
Sep 10, 2015 10:48 AM
Jeffwills14
Sep 6, 2015 06:52 PM
frost3
Aug 31, 2015 08:21 PM
