InfraRedline's all out turbo and build thread
Old Jan 16, 2014 | 09:45 AM
  #226
574's Avatar
574
Umm, excuse me sir, but I have :P
Not like you need it on 9psi though
Lol but really,
You'll either need that, or switch to draw through and a mega maf housing.
Okay
Old Jan 16, 2014 | 03:46 PM
  #227
SSfamilywagon's Avatar
Very nice man. Your moving along at a great pace. I'm interested in what your doing for fuel as some how we have the exact same issue.
I have already planned something out for mine, but open to some options as well.
Old Jan 17, 2014 | 02:20 PM
  #228
InfraRedline's Avatar
Richie, I'll message you about it later on today. Most of the stuff should be here early next week. Its pretty simple. Got a new canister on the way too, with no holes lol
Old Jan 17, 2014 | 04:39 PM
  #229
jhaddock21's Avatar
I'm also curious as to what your doing for fuel. I'm having some issues during long pulls, it leans out real bad and breaks up. I thought about sumping the tank like I've seen a bunch of srt4s have done and just run a big single pump that'll support 600+ on e85
Old Jan 22, 2014 | 01:04 AM
  #230
I havent touched the car since thursday, but tomorrow I wil get some things done.
I need to spell out my plans for the fuel setup, but my computer is so messed up, so it likes to skip letters, so it takes a long time to type anything lol. Essentially, I will be using my walbro 255 as a "lift" pump and it will sit on a bracket in the back of the tank and have a line running to the canister. It's primary job will be to keep a constant fuel flow to the canister, so under long pulls I won't be draining the canister anymore. The feed pump will be an AEM 320 E85 pump. Its really simple, and should work great.
Old Jan 22, 2014 | 01:51 AM
  #231
SPDDMN36's Avatar
Sound pretty neat.
Old Jan 23, 2014 | 04:10 PM
  #232
jhaddock21's Avatar
Updates?!?
Old Jan 23, 2014 | 04:28 PM
  #233
alerosaint's Avatar
i heard fuel pump gnomes works better
Old Jan 30, 2014 | 01:29 AM
  #234
Haven't done much on it in the past week. Got sick a few days ago and had some things to fix on the girlfriend's car.
I got the coilovers in late last week. Might need to get a little "dirty" with it, cause they don't go super low, but its about what I expected. Can't wait to drive with them! I also tapped the intake mani with a -6 bung to make the PCV port functional. Bolted the manifold and most of the charge piping up, drilled out the broken screw from my MAF pad and tapped that Mounted my catch can and ordered most of the fittings to make it work. Tomorrow I am going to have my friend weld in my EGT bung so I can put the manifold on and mount the turbo and the rest of the hotside.
Thats my little update for now!
Old Jan 30, 2014 | 09:09 AM
  #235
574's Avatar
574
So your fresh air is going into your intake manifold and not pre turbo?
Old Jan 30, 2014 | 10:37 AM
  #236
armcclure's Avatar
Lol no. He's gonna be probably the first with a full Powell/ARM full function pcv system.
Old Jan 30, 2014 | 12:50 PM
  #237
Pcv I will be doing next after fuel system.
Old Jan 30, 2014 | 08:26 PM
  #238
rico's Avatar
Subd. Great build .
Which coil overs u planning to get ?
Old Feb 21, 2014 | 01:24 PM
  #239
alerosaint's Avatar
Update
Old Feb 21, 2014 | 02:11 PM
  #240
SPDDMN36's Avatar
Last I heard it was running but had an oil leak on the turbo.
Old Feb 21, 2014 | 09:04 PM
  #241
Bluelightning's Avatar
Got Bewst?
I'll update what I know for Taylor because he's having computer problems haha. That's why he hasn't been on. The car runs and he has spent some time idling it. He just threw the bumper and everything back on last night. I think he still has an intake to make. Other than that it's ready to rip for the most part!
Old Feb 21, 2014 | 09:16 PM
  #242
BlackielawlessSS's Avatar
Nice, cant wait to see vids.
Old Feb 27, 2014 | 11:33 AM
  #243
Computer is FUBAR, started new job, been busy with that and working on the car, BUT the good news is my new computer shows up finally next Tuesday, and I'm at the point where I can start having some time and using it at work so I can be on the forums again lol because thats the only time I come on here!
As for the car, it runs. It has for over 3 weeks now, really well too! I could drive it if I wanted right now, but its so cold out, so I'll wait a week or 2 before taking it for its maiden voyage. I'll post some pics shortly if I can get on Photobucket.
Things left to do to have the car ready:
Purchase FIC 1200's from Alan
Weld up a 4" intake
Weld wideband bung in DP
Order 4 245/40 R888's for my new wheels
Fix a tensioner squeek
Put my in cabin Hallman Pro MBC in
Pull intake mani and charge pipe off for paint
Boost leak test
Get -4an union fitting for oil pressure gauge
Mount a few gauges and hook them up
Put on my ZZP LCA's and get an alignment
I think thats pretty much it for the most part, so pretty much done!
Old Feb 27, 2014 | 11:39 AM
  #244
SPDDMN36's Avatar
Taylor your alive!
Old Feb 27, 2014 | 11:47 AM
  #245
bmxracerchamp12's Avatar
doing an in car mbc?
Old Feb 27, 2014 | 11:51 AM
  #246
I am alive, and so is the car! Been busy with the new job.
Yeah, I'm running it in car.
Old Feb 27, 2014 | 12:16 PM
  #247
armcclure's Avatar
Like you're REALLY ever going to turn it down...
Old Feb 27, 2014 | 12:33 PM
  #248
I'll prolly run it around 450-500whp usually. 600 will only be a couple turns away and will take about 2 seconds lol
Old Feb 27, 2014 | 02:20 PM
  #249
Here's a few pics. I wasn't too good about taking in depth pics of everything, but I have a few decent ones. I just kind of get in the zone and roll with it when I am there usually.
From a few weeks ago:
Drilled manifold for the EGT bung
Bung welded in
Le turbo ready to go in
My fuel pump setup. I changed the feed loication just a bit after this pic. The AEM 320 is in the canister, and you can see the old Walbro 255 on the outside of it. The hose that is attached to it is pretty stiff, so it doesn't let it sag or sway more than a couple inches, so I didn't even have to make a bracket for it. Spliced the wires and used a connector as well. The pump sits right on the bottom of the tank 9" back from the canister, which is about 2" from the very back of the tank, so even with very low fuel levels this pump will fill the canister up. I have the fitting threaded into the canister and then siliconed with a gas resistant sealer that I have used on snowmobiles and such. It is at the bottom of the side and feeds right into the open space where the filter from the AEM sits. We will see how this works once the boost is turned up!
And the car back together last week She will get a bath in the next few days!
Old Feb 27, 2014 | 02:27 PM
  #250
ThexGovenor's Avatar
You will like the 1200's
