InfraRedline's all out turbo and build thread
I'm getting so pumped! Gonna run the shifter cables this weekend and probably bolt the flywheel/clutch/p-plate on and maybe put the trans on the motor. If I really get going I might put the motor and trans in the car right away, but I'm thinking I may wait a few days.
It was a much needed vacation from this hell we call ND
Also, I'll have 2-3 weeks off starting in 2 weeks before I start my new job so I'll be puttin in work!
Got a few things done this week/last weekend, but not a whole lot because I've been sick. I gots Bronchitis, ain't nobody got time fo dat!
Bolted up the flywheel/clutch/pressure plate, then bolted the trans up to the motor. Then I pulled the old shifter base and cables out and ran the new cables through the firewall and got the new shifter base and shifter in. Thats where I'm at now. Might put the mounts in and drop the engine in this weekend. Haven't decided yet.
The breather cap filter is simply for oil cap purposes until its in the car with the catch can hooked up lol
Made some more progress this weekend. It was -50* with the windchill, so I just turned the heat way up in the shop and stayed in.
Got the engine in the car on Saturday and started hooking things up.
6-speed fully installed and clutch mostly bled, snapped this pic after I finished up with the interior part of the install
And have most of the sensors hooked up and radiator hoses/coolant lines hooked up, this this where I left off yesterday. About to put the fusebox back in. After the initial start, a lot of this will come back out after I mark which wires I can still see and what needs to be moved.
Thanks guys. I got a lot more done this weekend than I anticipated. I was "maybe gonna drop the engine in" then I just got in the zone. Terrible weather makes me coupe up in the shop lol
I'm working in 70* actually, or whatever I set it to
