Injector question....
Originally Posted by 06blackg85ss
thats why most of us switch to bosch style injectors and a new harness... makes it easier
i guess i'm lost here...whats the question?...your stateing a fact about the two differant connecters...i dont see a question.
Fine...
The injectors that you put in your car... What type of injector are they? What brand? Are they an EV1 or the EV6 slim style? Also, factory injector harness... is it meant to plug into an EV1 or a "slim" EV6 injector?
See you can get EV1 injectors with a EV6 style connector and vise versa, Im asking because I need to know before I call world wide trading to find out my cost on a set of whatever i need.
Im assuming that the Cobalt uses an EV6 injector with EV6 style harness, but Im not sure. I keep reading that people are using a Bosch injector and an adaptor harness, however bosch makes both EV1 and EV6 style injectors.
Understand?
Originally Posted by StinkBOMB
Just a shot in the dark, have you considered going to one of the supporting vendors and getting injectors and a harness? I mean that's pretty much garaunteed to work.
Originally Posted by PhantomTA
Because, I am a vendor... Just not a supporting one... Sure im lazy and wont go look at the car to find out, but i assumed this would be an easy question.
Well maybe if you had a different attitude people would help. Now we are looking at you like go find out yourself. Do on to others my friend. You know the golden rule.
You never asked a question in your first post but you get mad when we ask what your question is. Later................good luck.
the only injectors available for our car aftemarket wise are bosch style which is why we switch the harness.... unless you go with the GM STG ones... those use the factory harness.... do some research with the search button... bunch of posts on this topic...
Originally Posted by SS_SC_Cobalt
injector harness is an EV1 if I remember but there are harness' to adapt us to ev6 (bosch style)
you can get these
you can get these
Okay, so we use the EV6 Injectors that have the EV1 style connector.
Thank you
Thank you
Thank you
From my understanding the stock injectors flow 4.3 gms/sec (34.2 lb/hr) and the stage 1 & 2 injectors are 5.3 gms/s(42.0 lb/hr) injectors.
These are the Siemens Deka fuel injectors.
helpful link showing our injectors technical specs
I replaced mine with the Siemens 70-60 lb fuel injectors made for LS1 LS6 LS2 Corvette GTO's..basically what Lingenfelter uses and same as what Intense sells.
http://www.lingenfelter.com/store/ln10070.html
You can find them cheaper elsewhere
Intense
http://www.intense-racing.com/Mercha..._Code=LSJ_Fuel
Just get a adapter harness like the one pictured above or from Intense or other vendors here. I think they go for around $45-50.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
