injectors 1000cc
injectors 1000cc
so i think these will fit my 60lb injector harness. am i right?
http://www.atpturbo.com/Merchant2/me...egory_Code=FUL
rofl, look at the injectors impedance!
(thats semi-fixable tho)
also, you'll have a hella hard time controlling them, AND you dont nearly need them.
you'll be relying on pure voltage * flow modifier....ewwwwww
try the racetronics 79lb'ers.
how much hp can the racetronics support and where can i get them. also can you pm me a little more info about your turbo build
curious as to what turbo you usewd to make that power and where it spools. basics of mine: zzp manifold, t3/t04e 57 trim .63 a/r, tial 38mm wastegate, tial 50mm bov. and im lookin to make around 500whp after the engine build this winter and i see your already there pretty much.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
