injectors 1000cc
Old Nov 11, 2008 | 09:01 PM
bwalker0510's Avatar
injectors 1000cc
so i think these will fit my 60lb injector harness. am i right?
http://www.atpturbo.com/Merchant2/me...egory_Code=FUL
Old Nov 11, 2008 | 09:08 PM
06black's Avatar
rofl, look at the injectors impedance!
(thats semi-fixable tho)
also, you'll have a hella hard time controlling them, AND you dont nearly need them.
you'll be relying on pure voltage * flow modifier....ewwwwww
try the racetronics 79lb'ers.
Old Nov 11, 2008 | 09:10 PM
SSdan's Avatar
Kinda low price too for an injector.
Old Nov 11, 2008 | 09:13 PM
how much hp can the racetronics support and where can i get them. also can you pm me a little more info about your turbo build curious as to what turbo you usewd to make that power and where it spools. basics of mine: zzp manifold, t3/t04e 57 trim .63 a/r, tial 38mm wastegate, tial 50mm bov. and im lookin to make around 500whp after the engine build this winter and i see your already there pretty much.
Old Nov 11, 2008 | 09:28 PM
06blackg85ss's Avatar
79lb'er are good to go. I'm making over 400whp and still got room to play with the injectors
Old Nov 11, 2008 | 09:41 PM
Sharkey's Avatar
those injectors would support 500-600hp. in reality, i dont think you will be able to properly tune something that big with a stock pcm.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
