Injectors
Old Apr 22, 2006 | 01:23 AM
dstinsman56's Avatar
Injectors
ok, so i have the rev it up stage 1 and i am thinking about getting the 42.5lb injectors and harness from intense. im sure youve all seen that hp tuners is close to releasing a tuner for it. my question is wether or not i should do that or get the stage one from gm. Is there is a possibility that the tuner will remove the rev limiter also.
Old Apr 22, 2006 | 01:49 AM
97CIVIC's Avatar
I Think You Should Get The Stage 1 First
Old Apr 22, 2006 | 01:56 PM
Old Apr 22, 2006 | 01:57 PM
Nuclear's Avatar
I agree
Old Apr 22, 2006 | 02:30 PM
BoomInIt's Avatar
If RIU don't release the next stage soon I will be doing the same, injectors,harness, hp tuner.
Old Apr 22, 2006 | 02:33 PM
BoomInIt's Avatar
Why spend an extra couple hundred on 40-45whp that is already there with the RIU stage 1? For that price we can then add the HP tuner and injectors....tune and get a 20-30 whp jump.
Old Apr 22, 2006 | 03:39 PM
thats what i figured and if the hp tuners has cracked the code then they will probably be able to remove the rev limiter or at least raise it to what ever you choose.
Old Apr 22, 2006 | 07:41 PM
zinner's Avatar
Moderator Alumni
If you are going to do the HPTuners thing then you will no longer need the rev it up box. GM stage 1 will also be a waste of money if you plan on doing HPTuners.
You will have complete control over everything with HPTuners. You will have to set a single field in your ECU for the injector flow rate. You can raise the rev limiter, you can disabled DTC's you can do it all.
I am waiting for HPTuners.
Old Apr 22, 2006 | 07:43 PM
patathSS's Avatar
Wait for HPTuners. 60# injectors here we come!!!!
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
